Just thought I'd share this - the brake cable on my blue car snapped a few months ago and I fixed it like so:
... with a couple bucks worth of standard hardware store stuff.
Bend back the end of the old one to form a loop around a new section of cable and clamp it. Then clamp then new section too. Then (with the brake lever down) loop the new section through the clevis, pull hard to get the slack out, bend it back, and clamp it.
Also, cut the ^&%$#@ little rubber accordion boots off both sides. As near as I can tell, their main function is to hold water and make the cable rust :roll:
