Parking brake cable repair
  • Parking brake cable repair
    Just thought I'd share this - the brake cable on my blue car snapped a few months ago and I fixed it like so:
    ... with a couple bucks worth of standard hardware store stuff.
    Bend back the end of the old one to form a loop around a new section of cable and clamp it. Then clamp then new section too. Then (with the brake lever down) loop the new section through the clevis, pull hard to get the slack out, bend it back, and clamp it.
    Also, cut the ^&%$#@ little rubber accordion boots off both sides. As near as I can tell, their main function is to hold water and make the cable rust :roll:
    man! mine is broken in the same place! I think im gonna do this, considering the yards are all muddy now.
    Now that ya got me thinkin, did you consider using those crimp on ones? Ive used those before and they can hold hundreds of pounds if you crimp them good (like hammer them on an anvil)
    89SX funtop! Fully loaded!
    RIP 90LX
      Stefan,
      You can!
      I pulled this from a post on the yahoo groups festiva site, from April 11th, 2001.
      Sorry no pics, but hopefully still useful.
      Both my '93's had the usual E-Brake failure!
      Both broke in the exact same place. Probably same as yours, in the
      guide/boot just before the connection to the mechanical actuator
      behind the drum on the passenger side! Fixed both for about $3.00 US.
      I'll outline procedure and fill in detail later if you need or want
      them.
      1) Jack up rear passenger end of car and remove wheel. Safety first,
      chock all other wheels, remember you don't have an E-brake. Support
      the car using jack stands, jacks are not for support they are only
      used to lift the car. Look over how the cable is assembled and put
      together. Draw a diagram, I did.
      2) Disconnect the part of the cable attached behind the drum. Its
      just a carter pin holding the Assembly together. Save the cable,
      note how the cable is routed and is retained in the "u" shaped piece.
      3) Next cut the cable somewhere to the right of the bracket that
      connects the left and right cables together, but left of the spring
      and stop Assembly. Again, very important, note how it is put
      together. Diagram this.
      4) After step 3) you can now remove all pieces of the cable and put
      them end to end. Measure how long this cable is and measure where the
      stops are located. Put these measurements on the diagram.
      5) Find a good Hardware store, I went to Lowe's, and buy steel cable
      in a diameter as close to the original as you can. Buy stainless if
      they have it. They only sell it buy the foot so you'll buy 2'. I
      bought four 2' pieces, just in case I screwed it up, and I did the
      first time.Also in the same section they will have wire connectors.
      these are used to join separate cables together or make loops in a
      single cable. Buy set of appropriate diameter for the selected cable,
      I bought extra, at $0.75 US a set was not going to break me if I
      didn't use them. If you wish, a special tool can be bought to crimp
      these connectors to the cable. I used a hammer, even though the
      directions on the connector package specifically says not to.
      6)Out of the wire connector set (they have 4 pieces in them) chose
      the largest 2 pieces. these will be attached to the cable ends. The
      smaller pieces,you only need one, will be used for the spring stop.
      7) Attach one of the large connectors to the end of the cable, using
      your choice of tool (hammer or crimp tool)
      8) now mark on this cable, as accurately as possible the distance
      between the spring stop and drum side connection from the original
      cable. Also mark the distance from the spring stop to the point were
      the cable is attach to bracket connecting left and right cables.
      9) thread the "U" shaped Assembly from the drum mechanism on to the
      cable, then the guide/boot, then the spring, if possible a small
      washer could be threaded onto the cable, to stabilize the spring base.
      10) place one of the small connectors onto the cable and side it to
      the marked location. Now crimp or hammer the connector to the cable.
      If using a hammer don't crush it flat but make sure it is not going
      to move from site of attachment.
      11) thread the above assembled cable, with all the attachment through
      the hole where the guide/boot will later be attached. run the cable
      through the bracket and out the other side. pull as much of this
      Assembly as possible through the bracket as the slack is necessary
      for you to attach the last large connector to the marked location,
      via hammer or crimper.
      12) if you did all of this correctly the Spring, guide/boot can now
      be attache to the subfram by its original clip and the "U" shaped
      piece can now be pinned back to the actuator behind the drum, don't
      forget the cater pin.
      13) If all is well your done! If you can't attach the "U" shaped
      piece to the mechanism behind the drum your bracket stop was too
      short. If you have too much slack you might be able to adjust the
      brake cable inside to car and take up the slack without engaging the
      driver side brake. If not the bracket side stop was placed too far
      from where it should have been. That's why you bough extras!!!!!!!!!!
      Cut the cable to remove the necessary hardware and try again!
      The manual says the cable should be fully engaged with between 11 and
      16 clicks of the brake handle, adjust accordingly.
      Hope this helps!
      Its been working for me now 3 months , prior to this, we didn't have
      an E-brake for over a year. As a plus this generally fixes the
      incomplete release or at least makes it much better than what it was.
        That confirms my suspicion about the rubber boots then - honestly, I don't see any use for them at all. Both of mine were full of rusty mud.
        Either is probably fine. The big advantage of the bolt on kind is you don't have to remove the whole shebang and put it over an anvil :lol:
          SS cable and crimp on fasteners are used to hold the masts up on sailboats (standing rigging, shrouds). The tool is called a "swager" for anyone who might be looking for one. You have to tighten them down hard to keep the cable from slipping out under stress later on. I've tried an anvil and cold chisel for steel cable on a garage door opener. It didn't hold first time. Be careful when doing that.
            bump to say thanks for the thread!
            same dang thing happened to me last week - fixed it this weekend. Leaving off the rubber boots sounded like a good idea to me too.
            93 Festiva - manual trans
            graphic design junk: www.standard-design.com
              Great post!
              Would this pass a safety inspection? Just a thought since replacements are hard to get.
              I have the exact same failure, broke at the rubber grommet thing. I'm going to cut off those bellows and splice in a cable. Thanks all!
              BP powered 91 Festiva L
              -FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
              -Trunk mounted gel battery
              -Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
              -Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
                darn, now i'm forced to post pix of my fix as well... tomorrow.
                  Congratulations guys! This is an awesome thread with good information to be sure. Even with the red Xs!
                  And it has earned you.
                  - Unknown
                  - Quentin Crisp
                  - Bumper Sticker
                    Good info guys....thanks again
                      man, i wasn't even paying attention to that, lol.
                        You know me, I read all the new posts and pounce when the opportunity presents itself.
                        - Unknown
                        - Quentin Crisp
                        - Bumper Sticker
                          yeah, you're just evil like that.
                            Could you post pics please...... I just broke mine and I have no idea what to do, and that is after reading the instructions, lol......
                            Thanks
                              Who do you want to post pics?
