since theres no ECM to cut fuel or anything? how does it work?
how is the rev limit achieved on the carb'd engines?
1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
2000 Trans Am 6 speed
1997 HD 1200 sportster
1986 Honda Rebel 250Tags: None
I don't think there is a rev limiter on a carbed motor. I mean they could put a restrictor plate sandwhiched between the carb and head, which would keep it from being able to substain enough air over a certain RPM, but I doubt Ford wasted time on that.
Just because It has a carb doesn't mean there's no rev limiter.
I have a rev limiter on my hot rod and it has a carb.
The rev limiter cuts the spark.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
there is NO limiter on the carbed festies except valve float. personally, my motor has seen the better side of 8000, but that's with a cam, springs and better coil.Trees aren't kind to me...
thats what i would have thought, but doesn't a rev limiter cut spark even on an EFI motor?Originally posted by elcamino1Just because It has a carb doesn't mean there's no rev limiter.
yup, the rev limiter is usually a function of the ignition system, BUT as in the case of my fiero, it also cuts out power to the fuel pump( or injector drivers, it's hard to tell) i do know fuel gets cut out somehow.Trees aren't kind to me...
what is the rev limit on a FI'd festiva?89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
mine cuts out at 6500 rpm. it sees that daily with 242000 on the clock. runs great!1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
i put an aftermarket tach in mine and the needle jumps at 6500 when its to the floor in neutral1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
I did notice that when trouble shooting an ignition problem in my 88, i swapped out the distro for another one and for some reason, the engine would cut out at about 6200. swapped in my old one and the limit dissapeared!!!???? the only thing i can figure is there's a disconnected wire in my old distro that's supposed to feed the ECU w/ info for spark cutout but i have yet to find solid evidence of this.Trees aren't kind to me...
