What is the thread/pitch on our wheel bolts?
  • What is the thread/pitch on our wheel bolts?
    i need to know the thread pitch ect on our wheel bolts so i can replace them with some conversion studs! im sick of having to hold my aftermarket wheels in place while i try to put my lug bolts in!
    thanks! i think once i figure out what the info on them is ill order up the parts and do a write-up on how to convert over to wheel studs and where to get the parts cheap!
    i think i might be able to get a VW conversion set cheap but need to know if they share the same thread pitch ect!
    thanks!
    12mm x 1.50 pitch
      Re: What is the thread/pitch on our wheel bolts?
      thanks!
      You too ^^ , I have had my wheels off , maybe 5 times in the last 2 weeks .
      Your write up will be appreciated .!!
      Thanks Matt
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        Originally posted by mattswabb
        12mm x 1.50 pitch
        you are my hero.
        parts should be in soon, ill throw up some links later tonight. and likely start a writeup on the part numbers and places to get them.
