while my car is idling i can hear a weird sound , kida like a bolt rattiling around somewhere. i tried to pinpoint the noise and it sounds like its coming from the starter or somewhere in that area. ill go listen to it some more , but its hard to tell where it is.
weird noise , kinda like a loose bolt rattling around ?
well , just checked it over somemore. if i press in the clutch , it stops. as soon as i let off the clutch , it rattles again. anybody ever had this problem ? im trying to find a loose bolt or something05 focus zx3 5spd 180k 2.5 inch mbrp exhaust , steeda sri and ford racing dynamic suspension
It could be a throw out bearing .
And it could be a bearing inside of the trans.
When you push the clutch in , you are stopping the power input to the trans , all the movement stops , when you depress the clutch .
How does it sound when you drive ?
When you drive it , is the noise still there , and will it go away when you push the clutch in , while the car is still rolling at slow speeds .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Originally posted by oxbrainIs the clutch cable loose on the fork and buzzing?05 focus zx3 5spd 180k 2.5 inch mbrp exhaust , steeda sri and ford racing dynamic suspension
