Noooo Crank ;(
  • Noooo Crank ;(
    Tried to start her up and I had no crank. Buzzer, lights, everything else worked fine. I'm getting the same effect trying to start it as you would with the clutch not pushed in.
    88' Ford Festiva
    97' Chevy Silverado Z71
    94' Chevy S-10
    fuse link bad?
    is it making any noise?
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    1951 Ford Deluxe, being rebuilt
    Have an old car truck or tractor? Go here.
    http://www.aintperfect.com/
      last week i jump in my car to go to work no crank. i open hood to find corosion and a crack in the positive cable end plus it was loose. weekend i fixed it and kicked myself for neglecting the basic maitanance
        I replaced my links with cartriges. They have been working well. Well i didn't think it was battery related due to the fact my wipers and lights work... and it wont even attempt to crank. I pushed the clutch sensor all the way in and still nothing. I pushed it a couple feet hoping something would change but no. The car hasn't been sitting. I drive it a few miles everyday. The only thing that has happened recently is a bad ground fromm the alternator so ive jumped it a few times in the past days. The ground wasfixed and the car charged and started fine untill this.
        88' Ford Festiva
        94' Chevy S-10
          i am stumped
            Did you check your leads on the starter itself?
              have someone try to start it while you tap on the starter.... that will anwer your questions really quick.
                I havnt checked any leads.. i will. And ill let you guys know.
                88' Ford Festiva
                94' Chevy S-10
                  +1 .. hit it with a hammer and it was goooood
                  88' Ford Festiva
                  94' Chevy S-10
                    funny how hitting something w/ a hammer can fix it
                      Had an 87 Escort that would do that about once every other week or so. Just kept a hammer in the car for that very reason. Just tap and go. Tho, what this means is that there is corrosion/rust on the brushes in the starter, possibly something to think about changing. Tho, with the escort, never changed the starter, just tapped it when it needed it for the last 3 or 4 years I had it. :roll:
                      1988 L - 232K miles Batstiva
                      1989 L - 247K miles Slick
