B3 removal
  • B3 removal
    93l 5 speed.
    im pullin just the engine not the trans and i want to know how to(if needed) unbolt the flywheel from the trancs because i cant find a spot to do it.
    Jason
    wishing i had a festi again
    Flywheel and clutch are bolted to the engine, not the trans.
      Ive always pulled the engine and transaxle as one unit, I know other will disagree though.
        thnaks the engines out now
        whats the easiest way to pull the wiring harness and and ecu.
        Jason
          Take off the driver's side fender and thread the harness back through the hole in the firwall into the car (assuming you've taken out the dash already).
          I used a pair of wire cutters to speed things up since I wasn't reusing the harness.
          ECU and other stuff inside are held on by either a 10 mm bolt or some plastic clips.
          White '89L auto - Sold!
          Silver '06 Rav4, 95k!
