i believe our A/C systems are of the Orifice tube type as opposed to the Thermal Expansion Valve, correct? if so then where is the orifice tube located? is it there where the lines go through the firewall or near the evaporator, or somewhere completely different?
A/C Question.
touch the high side line after the condensor with the a/c running, where it gets cold is where the orifice tube is (usually at a connection) usually right before the evap.Trees aren't kind to me...
The factory A/C that I just installed had a TXV inside of the evaporator housing with a drier next to the condenser. txv system needs a drier. orifice tube needs an accumulator. You can see it by pulling the fresh air selector housing down and looking into the evaporator housing. It looks like a brass mushroom with a line coming in the bottom and out the side with a themal-couple tube coming out the top that goes through the coil and is taped to the line on the other side. Why are you trying to locate the orifice tube or expansion valve?
EricBlue 1989 Festiva L 1.3 carb 160K+, Aspire 5spd, Aspire swap, Tach, Added A/C, Intermittent wipers.
Aqua 1991 Festiva L 1.3 FI 200K+, 5spd, Aspire swap, tach, Intermittent wipers.
Green 1995 Aspire 1.3 FI 95K (RIP Saved my 18yo sons life)
thanks for the correction, i wasn't sure which the festy used, but i know how to find the orifice tube on equiped systemsTrees aren't kind to me...
I thought that the r-12 systems used the orifice tube and accumulator and that the r-134A systems used the TXV and receiver/drier. my accumulator is next to the firewall, not near the condensor.1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
2000 Trans Am 6 speed
1997 HD 1200 sportster
1986 Honda Rebel 250
either system can use either style, it doesn't matter. all that matters is that there's a place for moisture to go and there's a pressure drop somewhere before the evaporator.Trees aren't kind to me...
ohh okay..well on the TXV systems, the receiver/drier is on the low side right? and the orifice tube systems the accumulator is on the high side?1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
