cel problem
  • cel problem
    well my cel (check engine light) has been coming on more frequently, when i was getting the car inspected, i asked the guy, i said "my cel is coming on after about 2-3 miles of driving, but wont throw a code, it resets its self." he said "if it resets its self, thats more than likely an o2 sensor." would this make sense to yall??
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    http://www.aintperfect.com/
    no, no sense at all. if it's reseting iteslf that quickly, you more than likely have a CEL high circuit fault (ECU runs a test to make sure the bulb is doing what it's commanded to) OR you have an intermitant short to ground before the ECU.
      o2 can intermitantly go out.....
        ECU does a bulb check I believe when the car is turned on .
        If it is not setting a code , then it is a soft code , that is a component that is not adjusting quick enough , that will make the light go on and off .may be a 02 going ?
        May be something really minor .
        If it is a hard code then it will set it and store it , that would most likely be a total failure of a component .
        HD2500 Duramax Chevy
        Z28 LS1 power 500 +
          soft codes are still stored in memory but won't set a hard fault untill the ECU sees the problem again (within a certain amount of time). check your memory codes (not active codes)
