my 93 is heating up more than my other one and it has a coolant leak that i cant find. (carpets not wet) but i cant see any smoke. could the head gasket be going? if not what other possibilities could there be?
head gasket question
yeah i took the thermostat out to see if that was the problem. and no that wasnt. my festiva is 5 speed also1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
2000 Trans Am 6 speed
1997 HD 1200 sportster
1986 Honda Rebel 250
i'm betting on a pinhole as well. if your system can't hold pressure, then it will start to boil internaly and overheat.Trees aren't kind to me...
Any problem with the coolant in the reservoir ?sigpic
not that i know of. it just sits there. the level doesnt seem to change and it doesnt bubble like it used to.1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
It use to bubble ? :shock:sigpic
yeah i re installed the thermostat with the little hole at the 12:00 posistion. and im about to go to advance and get a new cap! it would be nice if thats all it is!!1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
okay i just put a new radiator cap on it and that did not help. im thinkin i might swap radiators in my festivas to see if thats the problem. any other ideas?1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
Re: head gasket question
Originally posted by smokin fastiva(carpets not wet) but i cant see any smoke. could the head gasket be going? if not what other possibilities could there be?sigpic
OMG stop, just stop..... find the problem, then FIX the problem. your car overheats... is the radiator topped off (or close) after it cools down? if not, then you're loosing fluid and therefore pressure, causing the coolent to boil. Find the leak.
Are there any parts of the engine bay that are stained as if they've been sprayed by water? look for wet spots on the top and bottom of the radiator. is there evidence of water in the oil (or god forbid, oil in the water)? there's no white smoke from the tail pipe... not head gasket. if you can get the system to pressurise, (while the engine is running) squeeze the hoses and look for a stream or mist (use gloves for this, boiling water is HOT). Look for water exiting the firewall on the engine side behind the alt. WITHOUT the a/c running (if there is, you're heater core is bad). look for a waxy substance near the water pump and intake manifold.
report any and all findings and repair.Trees aren't kind to me...
You can do an intake manifold vacuum test to see if your head gasket is blown or if the head to block surface is warped.sigpic
