anybody tried this?? http://www.metacafe.com/watch/524517...as_mileage_2x/
acetone to double mpg's
Re: acetone to double mpg's
Originally posted by carbonvmaxanybody tried this?? http://www.metacafe.com/watch/524517...as_mileage_2x/
Though, I must say, this is one of the best "presentations" I've seen on this!
A trucker on another site I frequent did a study on his route using three tanks with acetone and three tanks without acetone. No difference.
But if you inclined please give it a shot and report back to us, I'd love to be wrong on this!'93 Blue 5spd 230K(down for clutch and overall maintanence)
There is no way this could work. Not more than just a tiny bit. There is simply no sound chemistry behind it. If there were, it would be been LONG know about and used through history. You can change octane ratings quite easily with additives, but doubling the mileage? no way. I would bet big money on it.Have had 6 Festys... and counting...
My Website:
Car Domain:
My Garage Page:
I tried acetone in my Turbo Coupe, didn't notice ANY difference.1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
There are a bunch around here that did a study on it , just like that trucker .
They did a 8 week test , there was no difference in mileage .
I know it sounds good , and I would love to see others outcomes, but I have not seen any actual positive results yet .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
HOWEVER: SeaFoam, which I have heard is MOSTLY just acetone, I can say from personal, and multiple experiences, can produce MORE POWER, and better MPG......
Http://www.Youtube.com/TheresGabe
1991 Festiva L Red: Daily Driver
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1991 Festiva L Red B6T: R.I.P.
1989 Festiva L White: R.I.P.
1995 Aspire 2-door White: R.I.P.
1995 Aspire 4-door Red: R.I.P.
I get about 42 - 46 MPG without Acetone and if with Acetone about 48 - 55 MPG if IIRC with math. Also don't forget I have a mod preheat fuel line before the fuel injectors that help a lot in cold weather!
EDIT:
I will show you pictures and results the before and after. (pretty interesting.)
Originally posted by gadelbert1HOWEVER: SeaFoam, which I have heard is MOSTLY just acetone, I can say from personal, and multiple experiences, can produce MORE POWER, and better MPG......
There is no acetone in it!
Never relie on what you "have heard"!
You need to get the MSDS to determine whats in it!
Oh, here I did the work for you:
^^ Cool ..Thanks John
I did not know it had alcohol in it :lol:------------------------------------------------
Z28 LS1 power 500 +
Originally posted by Pu241Originally posted by gadelbert1HOWEVER: SeaFoam, which I have heard is MOSTLY just acetone, I can say from personal, and multiple experiences, can produce MORE POWER, and better MPG......
http://www.seafoamsales.com/pdf/MSDS_SFTT_US.pdf
Thanks! You saved me the trouble of pointing that out. Something this guy doesn't mention is what acetone will do to your fuel system. It's a solvent, just like gas, but has different properties and will dissolve different things...like seals, some plastics, it will harden rubber lines....it goes on.
Jim
Originally posted by packrat427I did not know it had alcohol in it :lol:
Not aggressive like methanol, and even more miscible with gasoline than ethanol. Absorbs water and has higher boiling point than methanol or ethanol. Also good for diesels!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241Originally posted by packrat427I did not know it had alcohol in it :lol:
I know where that is going :lol: :lol:------------------------------------------------
Z28 LS1 power 500 +
