fired up the Nova today
  • fired up the Nova today
    was waiting for some fiberglass to set up ( will fill you in later) I stuck a battery in the Nova and fired it up.
    427, dominator carb, LOUD solid lifters.
    video link below
    money pit
    No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
    very nice.
    :cry_smile: RIP. 91 Ford festiva BP swap
    1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
      x2! i like the moroso valve covers!
        very nice...all that chattering reminds me how my Festy sounded before I started pulling the engine for the B6T.....but I have HLA's in it so it should not have sounded like that....lol
          Nice! Do you drive it on the street at all, or is it just a track car?
            Street only with a couple trips to "test and tune" nights.
            This year I calmed it down a little, changed intakes from a single to dual plane and took off the 250 shot of N20.
            Picked it up in California a little over 25 years ago and in my yonger years I was guilty of a little stop light grand prix. It would do low 10s back when that was fast
            I did the body , paint , engine ,tranny and narrowed the rear. To be honest the only person who has ever worked on it since I got it was the guy who did the front end alignment
            money pit
              OMG Beautiful car!!!!
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
                Awesome............and that's coming from a Ford guy! I like the ralley wheels and leaf spring rear. Very clean & subtle. What are the other specs? TH400 or PG? stall? Gears? I must be old, 'cause I still have a soft spot for the "Pro Street" style. Some day I'd like to do the same to my '71 Pinto, except probably with a stroked small block.
                BTW- hate to disagree with you, but low 10's is still fast.
                  nice! we had a 62 chevy II that I should have bought and beefed up... it was solid for an original NY car.
                  Facebook Me!
                    Rear - ford 9" detroit locker 3.91 gears
                    tranny- autogear Muncie M22 Wide ratio , super case, iron mid plate etc
                    Driveshaft -Dennys
                    Flywheel - Hays , centerforce clutch
                    Enigine 1968 427 4 bolt, factory forged crank. 7/16 rods , TRW piston at 10.75 CR
                    GMPP oval port heads ( edlebrock ) 2.25 intake , 1.88 exhgaust
                    Comp cam XE284 cam
                    Weiand team G intake, 750 Dominator ( now has a torker 4500 dual plane intake with ports
                    welded up to match the oval ports )
                    money pit
                      M22..........nice! Simple, efficient & dependable. I bet it's a blast to drive. Hows the 10.75 CR work? Can you run on 93 or do you normally run race fuel? It would be a good application for E85.
                        the compression ratio is fine , its a very light car, low gearing and the cam has a bunch of duration so runs fine on 93 although I stuck 100 in it when I was playing at the track
                        money pit
                          It's later now. What was it? I've been waiting since you posted.
                          -Bryant
                            Have to wait till this weekend
                            money pit
                              man that thing is nice! Not too flashy i love it. Theres an older guy near where I live that put a new 6.0 and 6 speed trans in a nova like that. Do you have to back off the timing at all to run 93?
                              Tyler
                              91 Festiva, 5spd, B8 swapped, now for paint and suspension
