fired up the Nova today
very nice...all that chattering reminds me how my Festy sounded before I started pulling the engine for the B6T.....but I have HLA's in it so it should not have sounded like that....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Nice! Do you drive it on the street at all, or is it just a track car?Brian
Originally posted by blkfordsedan View PostNice! Do you drive it on the street at all, or is it just a track car?
This year I calmed it down a little, changed intakes from a single to dual plane and took off the 250 shot of N20.
Picked it up in California a little over 25 years ago and in my yonger years I was guilty of a little stop light grand prix. It would do low 10s back when that was fast
I did the body , paint , engine ,tranny and narrowed the rear. To be honest the only person who has ever worked on it since I got it was the guy who did the front end alignment
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
OMG Beautiful car!!!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Awesome............and that's coming from a Ford guy! I like the ralley wheels and leaf spring rear. Very clean & subtle. What are the other specs? TH400 or PG? stall? Gears? I must be old, 'cause I still have a soft spot for the "Pro Street" style. Some day I'd like to do the same to my '71 Pinto, except probably with a stroked small block.
BTW- hate to disagree with you, but low 10's is still fast.Brian
nice! we had a 62 chevy II that I should have bought and beefed up... it was solid for an original NY car.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Originally posted by blkfordsedan View PostAwesome............and that's coming from a Ford guy! I like the ralley wheels and leaf spring rear. Very clean & subtle. What are the other specs? TH400 or PG? stall? Gears? I must be old, 'cause I still have a soft spot for the "Pro Street" style. Some day I'd like to do the same to my '71 Pinto, except probably with a stroked small block.
tranny- autogear Muncie M22 Wide ratio , super case, iron mid plate etc
Driveshaft -Dennys
Flywheel - Hays , centerforce clutch
Enigine 1968 427 4 bolt, factory forged crank. 7/16 rods , TRW piston at 10.75 CR
GMPP oval port heads ( edlebrock ) 2.25 intake , 1.88 exhgaust
Comp cam XE284 cam
Weiand team G intake, 750 Dominator ( now has a torker 4500 dual plane intake with ports
welded up to match the oval ports )Last edited by NovaSS; 06-05-2011, 05:13 PM.money pit
M22..........nice! Simple, efficient & dependable. I bet it's a blast to drive. Hows the 10.75 CR work? Can you run on 93 or do you normally run race fuel? It would be a good application for E85.Brian
the compression ratio is fine , its a very light car, low gearing and the cam has a bunch of duration so runs fine on 93 although I stuck 100 in it when I was playing at the trackmoney pit
