2nd to 4th pull!
  • 2nd to 4th pull!
    06 vw Bora
    09 Nissan Versa
    fastest B6T is back!!!
    http://www.cardomain.com/memberpage/785928
    why does it feel like i go through second gear a lot faster than that :?:
    Ian Carr
    88' flat black festy, has an e-brake that works!
    99' S70 T5M- faster DD
    86' 951- almost ready for track season
    My old b6t- wish i still had it
    http://www.cardomain.com/ride/2241793
    Every car I have owned has had a turbo in it, until I bought this latest festiva.. I plan to fix that though.
      There was driver and two passengers a full tak of gas and as you can see he took it easy.
      06 vw Bora
      09 Nissan Versa
        Thats nice ,It did not take very long to peg the speedo.
        HD2500 Duramax Chevy
        Z28 LS1 power 500 +
          touche
          Ian Carr
            u sure it wasnt 3rd to 5th??? video started at 35 and first shift was at 55....55 in second?? 85 in 3rd? is the gmr trans that much diferent that a festiva's...and is he using it?
            90 L FI..second B3
            90 L Parts car
            Jay
              G25MR ratios:
              Gear Ratio 1st: 3.31:1
              Gear Ratio 2nd: 1.83:1
              Gear Ratio 3rd: 1.23:1
              Gear Ratio 4th: 0.97:1
              Gear Ratio 5th: 0.80:1
              Final drive ratio: 3.85:1
              Festiva ratios:
              Gear Ratio 1st: 3.45:1
              Gear Ratio 2nd: 1.944:1
              Gear Ratio 3rd: 1.275:1
              Gear Ratio 4th: 0.861:1
              Gear Ratio 5th: 0.692:1
              Final drive ratio: 3.777:1
              55 in second is realistic. Use this calculator http://wahiduddin.net/calc/calc_speed_rpm.htm. The tire size is the radius not the diameter. The big difference I notice is cruising on the highway. There is a big difference in the 5th gears.
                matt your bringing the bpt to ff06 right?
                Ian Carr
                  Of course.
                    my apologies...
                    90 L FI..second B3
                    90 L Parts car
                    Jay
                      It was a 2nd gear start, I know this cause my car will do burn outs @ 45 in second and they end @ over 55.
                      06 vw Bora
                      09 Nissan Versa
                        on the 1/4 I had my BPTiva up to 93 in 3rd across the finish...thats the stock tranny.
                          The stock festiva tranny is something like 12% more over driven than the G25MR. Much nicer on the highway with the stock tranny.
                            I've noticed that when I'm driving my Capri on the Interstate. RPM only drops 500 or so when I shift into fifth. Sometimes I have to make sure it's in fifth instead of third. It feels like it should be way taller than what it is.
                              yeah 5th gear at 80 mph is around 4000 rpm... a very anoying pitch imo... luckly i just have loud music to cancle it out :roll:
                              Ian Carr
