Originally posted by neanderpaul
celica alloy progress
Dan
I think the muratic acid would be the better route to go there. I think it would be better for the metal in the long run, or so it seems.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Is the clearcoat messed up? If it is I would finish removing it with aircraft stripper and then polish them with a 4" grinder and one of these:
They actually come in different grits (coarse, med, fine and extra fine) and work great for removing paint gently without messing up the alloy. The finer grits will polish the alloy nicely too. I used them in a set of wheels just like yours and they came out very nicely.Oscar
would it be hard to find flares that would fit? Most cars fender wells would be bigger. Would that just mean that you would need to bend them to fit and cut as needed and then just use fiberglass or filler to get it looking right?Tyler
91 Festiva, 5spd, B8 swapped, now for paint and suspension
Nice work I cant wait to see the flares on
there was a sugestion of muratic acid - be very very careful with this - we used it at the dealer to clean up the aluminum steps and tanks on the used trucks that were traded in. if you dont mix it correctly it will turn your rims powdery white and they will look aweful - once you have them at this stage it will take many many hours with a scotch pad and several coatings of polish to make them shina again
However saying this if mixed right the acid wash does an excellent job of cleaning them up - you will still need to polish afterwards.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
I used aircraft cleaner, sandpaper, elbow grease and this http://cgi.ebay.com/10-PIECE-AIR-BUF...item2c52284e8d and when i was done I got this
and this. Worked out well.DV8 1 :twisted:
MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA
2003 Protege5
1983 Rx-7 Limited Edition
1991 Festiva (soon to be a 121)
1991 Chevy S10 pickup (R.I.P.)
1990 Chevy S10 pickup Bagged on all 4 corners
Paul, would you have a pic of the VW flares you were talking about?
I was looking into maybe doing that as we both have the same problem. I too have 195/60/14's. I like the beefy look from the wide and low offset wheels. They bad!
Someone has a post on here about some toyota flares too. Have that "bolt pattern"
look going around the flares.
Your White Festiva looks good like you've got it. Ever get those wheels as clean as you wanted?Dan
never got 'em clean. Working all the time. Staying up late working on a recording studio in my basement. Spent money on getting a new ride for the wife. Pics of it soon.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Pics of the recording studio when complete! What equipment do you have in mind?Dan
Pics asap for sure. The list of equipment will take a while. I'll post when complete. I threw another 5 hours at it last night. Up till 3 am again!youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
I'm holding my breath til I see a list!Dan
I'm considering running 240Z flares on mine. Fairly cheap, easy to find replacements, and so easy to find because like 50 companies have reproduced them. Plus they look good.Current cars:
