Sonic!
  • #76
    Car looks sick love it
    • #77
      Looks good now that you have complete bumper on it. Are you going to install lights to fill in those holes?
      -Brian
      No Festiva Yet But that’s coming Soon after I build the Vic (Dubbed Project SVTiva rear engine 4.6 DOHC from a Lincoln continental)
      My car: 2000 Ford Crown Victoria P73
      Mods:38mm front Sway bar, 31mm rear sway bar, Bilstine shocks, Aluminum drive shaft, 3.55 gears w/ Posi. Coming Soon: 5.4 liter SOHC (Full N/A build) w/ 5-speed Trans.
      • #78
        its truly beautiful!
        • #79
          I have some ideas but haven't executed yet. Volkswagen bulbs fit pretty good but I'm worried about heat.
          1989 Ford Mustang GT 5.slow
          1996 Ford F-150
          • #80
            How hot do they actually get? They look great
            • #81
              I'm not sure, didn't get to run them. But I would have to modify the valence some more to fit these bulbs.
              1996 Ford F-150
              • #82
                have you looked into hellas? i put a set in for my dad on his 97 ranger and they didn't melt anything yet.
                Facebook Me!
                • #83
                  Yeah that's what I was looking for. I didn't buy these bulbs just had it sitting around so threw it in to see what it looks like.
                  1996 Ford F-150
                  • #84
                    I wonder how difficult it would be to wire a relay through the neutral switch so the lights can't be on when in park or neutral (at least on an automatic)... That way the lights won't over heat when left on and not moving to cool them off.
                    -Zack
                    • #85
                      The ford ranger fog bulbs 893?890?997? i think are a 35 watt. GM has one that fits and its 50-55 watt. I use those in my Dodge srt-4 with upgraded harness and no melting on the oem plastics. Yes i went to school and took English Comp LOL. Yes the ranger and dodge neon fog bulbs are the same.
                      I would just add a relay. What i did on my car for a while was flip the headlight and fog wires @ fuse box to run the fogs as driving lights when it's dusk but that got old and I think i get better mileage in my head running just one set of lights. My vacuum at idle is actually different, less load on the alternator.
                      1993 GL 5 speed
                      • #86
                        I ain't got no English degree but that's some usefull info right there. Thanks, I'm checking it out.
                        1996 Ford F-150
                        • #87
                          Sonic received a full heart transplant. Here's the kicker's went to start clogged injectors, went to start again fires up starts puking oil (front crank seal, start it again just chugs (dizzy rotor button broke off). So finally after a long day started at 10:30 a.m. Drove it home around 2:30 a.m. She's home safe and sound. Eurotiva has more pics.
                          1996 Ford F-150
                          • #88
                            What was wrong with the old one?
                            1991 blue L, 5 speed.
                            1988 red L-plus-all stock.
                            • #89
                              On my '96 Saturn 5-speed the running lights turned off when the ebrake was up... same principle but works on a stickshift. Cause it would get a little crazy in a stickshift if they blinked everytime you hit neutral between shifts! Lol
                              No festiva for me ATM...
                              • #90
                                Was that the motor lurkin' around the back of the Festy garage?
                                '93 Green L - ' Tiva
