Swapped the radio and cup holder
    Ooooohhhh.... sweet idea!! I have those little sponge donuts stuck on top of my dash, and they're great if the only thing you want is a large coffee. Anything smaller falls out, and anything bigger as you know....
    Drives me nuts when I go through McDs and have to rest my pop on top of the emergency break and lean it against the seat. Been looking all over for after market holders to modify, but haven't had any luck.
    Nice work!!
    Cheers!
    Fishtiva
      Is There any trick to getting the cup holder out of the taurus????.....any info in how you fastened the cupholders in the radio area????
      I'm planning on doingt this as well....any info would be great!
      Previous owner of 8 festivas... looking for number 9
      Adam
        The cup holder has metal tabs on the side and since I was not worried about damaging the taurus I used a flat head screw driver and wedged it down in between on the sides and pryed and pulled on one side and then the other...pulled it out.
        As far as installing in the Festy. I used a plastic mount from a radio installatin kit. Slid it into the collar until it locked on to the tabs and then screwed in just like if I was putting in a radio. You will see four little tabs behind the face plate of the cup holder that you would need to snap off but other then that nothing special.
          Where did you get the cup holders from?
            [QUOTE=Sleeper;86288]Is There any trick to getting the cup holder out of the taurus?
            Use the same tool that remove's the radio.
            99 Dodge Caravan SE
            95 Taurus SHO auto 265hp
            94 F150 351W auto (for sale)
            95 Honda 1500 Goldwing SE
            95 Iszuzu Trooper LS
              You can make one easily from a coat hanger. Cut 2 pieces long enough to make a loop for each side, shove all 4 ends into the holes at once, then pull it out. i bought mine (Schoche) at wally world for 5.00 or so though. Those drink holders aren't popular in the Taurus crowd. Most want the storage cubby instead, and drinks don't fit real good in them. Small coffee is about all that you can get in them because of how they sit against the dash. I have a 93 SLO myself. Never use it. Still like the drink holder that I use on the passenger door instead of the door pull. Wife hates it when she is riding there though. It holds 2 King Cokes from Burger King snug.
              Michael
              Have owned 9 so far
                levitan had tons of coin/ cup holders for sale look in the fs section i have one comin along with some other stuff just throwin it out there
                RJ
                  how do you get the radio to fit in the change catcher thingamaduller?
                  87 rx7
                  92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
                  94 caddi deville
                  99 f250 LD 4x4 12 inch lift on 38s
                  i need more festies.
                  • #24
                    I hate to bump an old thread but I'm planning on doing this with the new Festiva I'm getting.
                    I already have the console and radio out of the car, how does the radio mount inside the console? Does it just fit in there? What do you have holding it in there? Basically I'm just asking for a more detailed explanation on how you did the install. Thanks for the info in advance.
                    • #25
                      you have to do some cutting on the console. The radio sits on the little shelf in the cubby. If you are coming to Ohiostiva you can check it out first hand.
                      • #26
                        I'll be there and I'll check it out
                        • #27
                          wondering if you could use this cup holder with the original shifter.
                          • #28
                            Yeah, you can use it with the original shifter.
                            '90 LX
                            • #29
                              Talk about reviving an old thread :lol:
                              • #30
                                got a festy about a year ago and the only thing i dont like is that it doesnt have any cup holders.
