So i think i will start a new build thread since its a new car. This car says 'Canadiana' on the side, so thats its name. same plan as in my last build thread http://www.fordfestiva.com/forums/sh...ad.php?t=58782 and everything i want to do and have done so far is in that thread.
So, just a quick update basically. ive been working late every night trying to get stuff done since not finding a car for a while put me way behind schedule.
I stripped out most of the interieor and washed the inside. and that sure takes a long time! I only spent 12hrs on a saterday installing sound deadner because i had to work on on my civic and a few other things too.
Started with the passenger floor
that stuff is really difficult to press into all the contours and isnt all that sticky.
Then started on the door. i put the deadner on the entire outer skin including behind the crash bar, covered that bar and then put as much as i could on the inside of the inner skin. the door sound amazing when you close them now
I left room for the rust on the bottom (dont want to seal moisture in there) and sprayed fluid film (basically wax oil) in the bottom of the door. i also filled the rocker panels with it before doing the sound deadner on the floor.
Then i moved on to the rear quarter panels and the drivers door. i covered everything i could on the outer panel and the inside of the inner skin again, leaving room for water to travel and rust to dry out. sprayed all the metal there too.
My hands were cut to pieces after that. i didnt want to touch anything for like 2 days. they are still a bit messed up and swollen now almost a week later. everything inside the car is sharp and the sound deadner is aluminum backed and you cut it with tin snips, then i was pressing it in by hand. get a few sharp edges every now and then.
That was just saterday, ill have to update what i did this week later on.
