is that a msd 6al-2 on that car above?
b3 turbo questions
Mike, AKA the sasquatch
cool
 i am gonna get a 6al-2 when i do my motor swap
cool set up man and i do wish mine spooled a little sooner, but i could not ditch the a/c because it is hot down here year around, I think I might benefit from a little smaller turbo too. Mine is an old eclipse turbo. Just being different, just like owning a festiva-Greg
Redneck Engineer
FOTY - '09
it doesnt matter where you mount your turbo when you compress air it gets hot thats physics. if intercoolers didnt work then why would anyone use them. And how can you promise yours gets more complements? How about this i promise intercoolers are better!
PS resuwrecked thats a sick paint job i love itLast edited by 187festiva; 04-20-2009, 03:26 AM.
not saying without is better i just do not need one my 14 foot pipe serves as one lets change subject-Greg
Redneck Engineer
FOTY - '09
This manifold came out pretty good! did you have any trouble with the stock manifold cracking?Originally posted by resuwrecked View PostWhen I 'charged my old b3 I chopped the downpipe flange off an aspire manifold and welded on a turbo flange...I have another vj11 and aspire manifold I may put on my other car.
What did you do for fuel managment at 10psi?Last edited by iceracerdude; 04-20-2009, 10:33 AM.
a 12to1 fmu and an extra inline fuel pump and less timing-Greg
Redneck Engineer
FOTY - '09
Cyl 1 primary did crack once, so i unwrapped it and welded it and all was good. Be sure to use a turbo brace when using tubular manifolds. I was and it still cracked, probably from the heat. I ran the dog **** out of it daily for almost 2 years before doing the bp swap. I replaced the in-tank pump with a walbro255 and used the 12:1 for fuel and had almost perfect afr's till about 10-11psi on stock injectors.Last edited by resuwrecked; 04-20-2009, 10:53 AM.
Is the flesh chalkboard paint? Which bp swap did you do.? I think i found a bp for my festy last night. 91 proto with a sohc 16v is that a b6 or b8? Thanks
Greg-Greg
Redneck Engineer
FOTY - '09
That is a B8, not a BP.Originally posted by eurotiva View PostIs the flesh chalkboard paint? Which bp swap did you do.? I think i found a bp for my festy last night. 91 proto with a sohc 16v is that a b6 or b8? Thanks
GregThe Festiva Store
hanks again for all the help Ill keep everyone updated on the turbo project. Im picking up a 90 fuel injected funbox at the end of the month and have most of the parts, I still dont know what injectors I should use though, and I am going to use the safc2 but not sure what response I will get from the motor. One of the first things Im doing is going to the pick and pull and getting a spare motor because chances are I will blow mine up because it has a modest 212,000 mi on it and I dont think she'll like being boosted (but thats not her choice its mine, lol). but anyway Ill keep everyone updated
-thanks again
