Originally posted by bobbyspider
		Then this all has to be welded together, because there's is no aftermaket manifold made for the b3. I do know of a guy who can cut flanges from gaskets for you, but you'd still have to do the rest. Now you have to make your charge tube as well, then figure out, should I do a blow off or bypass valve setup. Oil line in and oil drain out, coolant lines in and out. Next your down pipe set up etc.etc.etc.
Believe me, I'm not trying to rain on your parade, but this is a monumental undertaking. Ask me how I know!
And if/when you do it wrong, you'll blow up the engine.
Here are some pics of my setup, all made by hand, and with a lot of assistance/favors. Click images to enlarge:
From the bottom
This was originally a fuel injected b6, sohc 99% of the parts fit onto a b3. That's a forge bypass valve up top.
The turbo is a kkk k03
And these is only the things you can see...there's more to it. IMO
