b3, b6 interchangable parts?
  • b3, b6 interchangable parts?
    since the b3 and b6 are so similar can the b6 exaust manifold be used on the b3 stock motor? I searched and couldnt find anything on this so I figured Id ask. What other parts are interchangable just curious.
    Yeah they bolt up, but the b6 hangs down closer to the ground. You'd have to do a simple section cut on the down pipe. I don't know what happens at the cat, because I always take them out of the system!
      what about the rods, not the pistons and rods just the rods alone?
        yes, rods alone are interchangeable from the B3 and B6.
        -Aspire brake swap COMPLETE!
          sweet, I know that I should just swap but Im just checking my options. I will end up swapping but I just want to get a little more familiar w/ the car first. and thanks for the correction ice on my last thread about the cam (not more fuel) better air flow.
          - I pick up the funbox on sunday
            what about fuel injectors and the throtle body?
              I know the throttle body i.d. is bigger and i know that the injectors will fit if you have the denso type ( I had a festy that had bosch type and were a little bigger) but they are more flow which will cause a rich condition at idle/off throttle and all around running bad
              -Greg
              Redneck Engineer
              FOTY - '09
                when you go boost what happens to the mass air flow sensor
                  if you do it properly it ends up in the trash bin lol...
                  Mike, AKA the sasquatch
                    will this leave the check engine light on?
                      no it was a joke... if you unplug it the car wont run right....
                        ha ha :p I gota be quicker than that
                          what mazda motor is in the ford probe gt, the older ones
                            FE2 it is a 2.2l turbo
                            the newer one is a yamaha injected dohc 2.5l which I have seen swapped in to a mx3 that ran 11's
                            I think he is referring to using a map sensor
