since the b3 and b6 are so similar can the b6 exaust manifold be used on the b3 stock motor? I searched and couldnt find anything on this so I figured Id ask. What other parts are interchangable just curious.
b3, b6 interchangable parts?
Tags: None
Yeah they bolt up, but the b6 hangs down closer to the ground. You'd have to do a simple section cut on the down pipe. I don't know what happens at the cat, because I always take them out of the system!Last edited by iceracerdude; 04-26-2009, 04:07 PM.
yes, rods alone are interchangeable from the B3 and B6.
-Aspire brake swap COMPLETE!
sweet, I know that I should just swap but Im just checking my options. I will end up swapping but I just want to get a little more familiar w/ the car first. and thanks for the correction ice on my last thread about the cam (not more fuel) better air flow.
- I pick up the funbox on sundayLast edited by bobbyspider; 04-27-2009, 12:01 PM.
I know the throttle body i.d. is bigger and i know that the injectors will fit if you have the denso type ( I had a festy that had bosch type and were a little bigger) but they are more flow which will cause a rich condition at idle/off throttle and all around running bad-Greg
Redneck Engineer
FOTY - '09
Originally posted by bobbyspider View Postwhen you go boost what happens to the mass air flow sensor
Mike, AKA the sasquatch
Originally posted by bobbyspider View Postwill this leave the check engine light on?
Originally posted by bobbyspider View Postwhat mazda motor is in the ford probe gt, the older ones
the newer one is a yamaha injected dohc 2.5l which I have seen swapped in to a mx3 that ran 11's
Originally posted by bobbyspider View Postwill this leave the check engine light on?Last edited by nonamekid; 05-10-2009, 08:53 PM.
