Has any one installed a 4 in 1 header on a b3? Does it makes more power? If I install headers, do I have to increase the exhaust pipe diameter?
FMS sells B3 headers. I'm gonna buy one for my Aspire. They will not help in the low RPM range, but will help in midrange and higher RPM; maybe 2500 - 6000 RPM.
I wouldn't increase exhaust pipe diameter though. It decreases exhaust flow speed.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
DON'T use the B6 header for a B3, the primary is way too big. Tom, if tuned properly, a header can increase the low end torque of an engine. but typicaly they're tuned for upper RPM power.Trees aren't kind to me...
^ I'm going to guess that mattdickmeyer is at work so waiting 12hrs really doesn't give much time to respond, espically on a fairly slow board such as this. Give it time young Padawan.
Im guessing around $100 in shippingIt's a good thing you don't read the stickies, you might of learned something.
Poverty produces creativity
Matt, are you still offering a DIY pre-bent header kit? Could you do a Tri-Y design or just the 4-1 ?Brian
Originally posted by mattdickmeyer View PostOn the dyno, my header increased hp & tq through out the entire rpm range, though likely wont be as much on a stock b3. I'm selling my header if your interested.:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
Cold air = marginal increase, spark plugs/wires unless the ones on there really are old & sucky = again marginal increase.
A new cam will be the single largest increase that you can get without forced inductionIt's a good thing you don't read the stickies, you might of learned something.
Originally posted by lancerevo View PostIt have a cold air intake. Does It makes a difference in power? Also If I buy a set of brand new spark plugs leads will it increase power?PROPOGATE! AND FACILITATE!
