Originally posted by grey
Will a B3 head fit on a B6?
yeah the head will fit w/o issue, i'm using B3 intake and exhaust on my first gen B6 head, all the mount points are the same. there's no spicific writeup about the exhaust runner, but i can tell you that there's plenty of material able to be removed before you hit a collent passage. the B3 head SHOULD give the B6 more pep down low with the higher compression and higher intake speeds at low RPMs. i also doubt any issues with valve clearance, but i WOULD use some clay and verify first.Trees aren't kind to me...
I really hope I dont have to go this route, but... there are no b6 heads here.
I am more concerned with performance at highway cruise speed. This 323 mazda is a 4 speed. I have never driven it, so that is a big question.
When, I say "performance" I mean a reliable passenger car.
I have never checked piston/valve clearance with clay. I assume the valves on the b3 head are in a slightly smaller circle. I could enlarge the cutouts in the pistons...or is that a bad idea?
Thanks for the information.
I didnt look at what year the Festiva's were. I know the were single cam B3 with fuel injection. I think the distributor was different, though.
Will the mazda dizzy fit on the ford cam shaft?
Refresh:
I have an 88 B6 with a warped head. I have to use a B3 head .Last edited by nonamekid; 11-16-2009, 02:01 PM.
highway performance shouldn't change.
don't attempt to cut the pistons, not worth the headache. checking with clay is easy. torque the head down (with head gasket), install the timing belt and have a pair of valves installed in the head. then carefuly rotate the crank 720*. i say carefuly because you should be able to do it by hand (with a breaker bar) and if you feel any resistance (rotation stops) then you've touched a valve. if you can complete the 720* then you pull the head and inspect the clay with a micrometer. you only need a nickle sized ball ov clay for each valve.
the dizzy will fit w/o modificationTrees aren't kind to me...
i ran a b6 head on a b3 block for a year, you should think of shaving the head a bit to regain the compression loss, but it worked fine, and there was actually no carbon build up around the "shelf" created on the top of the block whn i eventually pulled it off, i used the b6 head gasket also
First, what does "top end" mean exactly?
I have been trying to decide what to do.... whether to use the warped b6 head that came with the car. It is back in decent shape now. Got the valves to fully seal anyway.
A proffessional shop had said the b6 head was no good. (heard this from the guy who sold me the car) I dont know why they said that. I have cleaned it up and "inspected" as best I can. If there is a crack, I dont know how to find it. They had not cleaned the gasket off, so whatever they saw is something besides the warpage.
"top end" the upper RPM range of an engine, usualy relating to the performance within that range. "not having top end" = no pulling power past 4000 rpm. the engine will continue to rev up but it will do so at a slower pace.
if the head is warped past a certain point, it's considered BAD. just pull the B3 head and slap it down on the B6 block with a B6 head gasket.Trees aren't kind to me...
Yes I have the FSM spec, and it looks to me like it is at the limit to correct the warp plus a little more to get the fire ring dents smooth. (My measures are only a little better than nothing)
I can spin the cam shaft easy
Do the B3 and B6 share the same cam shaft? Have these been interchanged by anyone ? Also, HLA's?
The B3E is not shown atOriginally posted by grey View PostDo the B3 and B6 share the same cam shaft? Have these been interchanged by anyone ? Also, HLA's?
Maybe you have seen the specs foe B3 in the FSM or posted here?
B6E Valve Timing
Cam base circle
Intake duration
244° @ 0.003"
Intake opening
14° BTDC
Intake closing
50° ABDC
Intake lobe height
36.451mm (1.4351")
Intake valve lift
Exhaust duration
244° @ 0.003"
Exhaust opening
52° BBDC
Exhaust closing
12° ATDC
Exhaust lobe height
36.451mm (1.4351")
Exhaust valve lift
Valve overlap
26°
The B3E is not shown atLast edited by grey; 11-24-2009, 11:09 PM.
