what size primary are you using?
Ram Header
Mine is from an 86 323, so the B3 header will work?Originally posted by muscle_Car1 View PostIf he's making one for the B3 then it will fit the early B6Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
I have a b6 header....Originally posted by hotfordcat View PostMine is from an 86 323, so the B3 header will work?-Greg
Redneck Engineer
FOTY - '09
^ thank you. would you recomend stepping to 1.5 for the B6, or are you on the large side for the B3 to account for the additional turbo volume?Trees aren't kind to me...
would 1.5 inch on a bp be to big?
Mike, AKA the sasquatch
so a 250hp or more bp and 1.5 inch piping for the manifold would be ok? what about the exhaust after the turbo? im wondering if i should go 2.5 inch or 3 inch....
sweet, thanksOriginally posted by mattdickmeyer View Post2.5-3.0 would be fine as you want no back pressure out of the turbine . This will lower egt's ( good for exhaust valves and burning oil off valve guides) and increase turbo response!
"A turbo works from and causes backpressure in the header" if this is the case,then the turbo is the restriction and primary tubing size would be irrelevant....1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
^ i think it has somthing to do with velocity... the smaller the pipe the higher velocity the air will be going...
Poverty produces creativity
