My uncle has a 5speed aspire and this is the second tranny that has went on him and now the junk yards have run out of aspires but they do have festivas so he was wanting to know what is needed to swap a 5speed festiva transmission into a aspire.
i think its like this. correct me if im wrong
-it will bolt up
-use the aspire axles?
-both being e-series you can keep the aspires clutch?
-for the mounts ive read multiple things but pretty much if you have both festiva and aspire mounts some combination will work.( use festiva front mount mentioned most)
-swap sensors
-aspire shift linkage and clutch cable work fine?
did i miss anything?
Thanks in advance.
TimS
-it will bolt up
-swap sensors
Thanks in advance.
TimS
