If I were to tubocharge a rebuilt stock B3 and add a (well controlled) nitrous system, could it end up comparable to a B6 swap? I ask this because I like the fuel economy of the B3, but also value speed/ acceleration.
I would put a limit switch on the engine on the throttle assembly to only activate nitrous at WOT, and only when a switch is flipped in the cockpit. I also would probably need to aspire swap for stability.
I'm hitting up 6 local yards today. Hope one has a festy...
