Originally posted by hofficergrover
		So if the ATX Festy axle fits due to the fact that its inboard spline count is 24.And you are saying ATX non abs Aspire will work as well.That means these two are identical in length. With that being said,the ATX Aspire axles must be shorter than MTX Aspire axles.(Because we all know the Aspire is @ 3/4" wider) than a Festiva. According to my research the NA Capri axles will be 1/4 to long per side for this topics application. (F series in a Festiva) But this could easily be accounted for with Aspire LCA's.Wasn't the 89-90 323 @ 1.5" wider than the Festy? And came equipped with the F series instead of the E series?
hofficergrover- would you be so kind as to post your research results.Specifically pertaining to Aspire/Festiva ATX left/right axle lengths .This would be greatly appreciated.I have no info on either ATX lengths.
I cant see using the 89-90 na 323 axles for this topics application.They are going to be @ 3/4" to wide per side.
By my calculations the na Capri axles with Aspire LCA's would be the very best fit for this topics application. Please anyone with info chime in. I'm only trying to get all this straight. Thanks folks-
Also I have an Aspire that I want put the F series in. Can I use the Aspire axle with the 323 F series inner installed on it. Or even better should I just try an ATX Aspire which would give me the 24/24 spline count that I need.Thx-Nitro
