you people are all forgetting about the old Cosworth Grand Prix 1.3 turbo motors.... they were making close to/over 1000 HP. it can be done.... period. so yeah, they had 16 valves and bomb proof bottom end, but the numbers were there and they won races.
200 hp NA is a staggering number for a B3 requiring 2.53 hp per ci, NASCAR engines only produce about 2.2 hp per ci. Here's where the B3 can make up for the loss of cubes... RPM. Figure that the NASCAR engine can make 2.2 hp @ 9000 rpm, the B3 (if built correctly) can pull to almost 12000 rpm. the problem is that it won't be streetable, nor will it last like Ra wants it to, and the required octane is expensive s#!t.
...just went to an online HP calculator, i gave the festy a race weight of 1750 w/ driver and a 13 sec 1/4 mile time. It told me that Ra would need about 160 hp at the wheels and 205 at the crank. THIS IS JUST AN ESTIMATE.
...and i just ran a calculation for required torque@rpm = HP: Ra would need 132 ft/lbs @ 8000rpm to make the 200hp mark at the flywheel. that's A LOT!! of torque. now, if we up the rpms to 10k, the required torque drops to 110.2 ft/lbs. AT 10,000 RPM.
my $.02
EDIT: I own page 4!!!! muahaha :wink:
my $.02
I hope you're not being "taken for a ride."
