A buddy was discussing the escort coil pack and a trigger wheel are adapted to several different vehicles to eliminate their distributer. Has anyone done this to their Festiva?
anyone familiar with EDIS?
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
there is a gentleman doing a B3 swap to his miata and he is using the miata DIS.
there is a thread about his build somewhere about 2 days agoTrees aren't kind to me...
Seen that, just didn't have enough info. I didn't see where they actually made it work.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
the build hasn't gotten that far yet.Trees aren't kind to me...
Miata DIS and ford EDIS are *very* different systems. The EDIS is an independant system, and only has minimal communication with the ECU (spark/tach + timing signals) whereas the Miata system is all in the ECU, the ECU fires the coils.Originally posted by FestYboy View Postthere is a gentleman doing a B3 swap to his miata and he is using the miata DIS.
EDIS and Miata CAS/Coilpacks can be adapted to b-series engines, but you need a standalone ECU to manage them. (there was a standalone spark controller at one point, I don't think it ever took off) Or OE engine management conversion (such as Miata ECU into festiva)1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
To add to this , Ford also has their DIS ignition modules.
Its only found in the V6 SHO (89-95) and the 3.8 Supercharged (T-bird SC Cougar)
Not that , that ford DIS is NOTHING alike the ford e-dis , its 2 separate things.Last edited by PhoenixSHO; 02-25-2012, 11:20 AM.
Someone at madness had this system, but I didn't realize what it was at the time. I with they would chime in.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
I'm really thinking of adapting this to my car, its basically a stand alone system. I would like to get a little more insight before I jump into it.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
It's a very independent ignition system, but it still needs control, and short of a standalone it's not going to work. There's no way to make it talk to the stock ECU, it's not setup for that. Don't mean to crush any dreams here, but that's the reality. Megasquirt works really well with the ford EDIS system. Going with Miata CAS is a bolt-on affair but a little harder to setup, but also works well with the MegasquirtOriginally posted by gauge_half_inch View PostI'm really thinking of adapting this to my car, its basically a stand alone system. I would like to get a little more insight before I jump into it.
The M90's way too bigOriginally posted by M3NTAL View PostThere's a sc bird in the yard right by me I've been wanting to grab the charger n compound boost pinky but I don't have any fabricating resources
Plus I think that eaton is too big
M62 is also too big, but could work. The M45 from the Cooper S is a good match
Rocketchips!
I found a spark stand alone system called mega jolt. Kinda like the spark only control system of the full megaquirt.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
How come you want to eliminate the stock ignition? Just want peace of mind?Originally posted by gauge_half_inch View PostI found a spark stand alone system called mega jolt. Kinda like the spark only control system of the full megaquirt.
Jus wondering--Some people like to read fiction,I prefer to read repair manuals. Weird I know-
With the 14 psi I'm cramming into my little sohc, I'm not really in a position to go megasquirt just yet. I have a fuel controller but no way to modify the stock timing maps. I have my base timing pulled back to 7deg and still getting a littlespark knock over 5k, the bottom end/out of boost power has declined trying to keep it from detonating up top. I would LOVE to run cops to elliminate the possible change of blowing out the spark, and want to keep it as advanced as possible at the bottom end without having spark knock.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
