Originally posted by zoom zoom
Focus axle info
Yes its a fact,they had G's.They were the evolution of the EGT.Without a Mazda engine.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Why swap bell housings? It's the same tranny internally as the Capri XR2Originally posted by zoom zoom View PostSo it will not bolt up to a b series motor, is it possible to swap the bell housings and make it work?
The axle seals should be ok, I am still using the KL axle seals with the Capri axles and no issuesOriginally posted by nitrofarm View PostThat is why I want to use the ZX2 engine/tranny that way I dont have to worry about flywheel/clutch compatibility.
Just not sure on the axle seals.And I've got a couple ideas on using the EGT ball joint.
So considering the ZX2 already uses a 26 spline diff, the axle diameter should match up to the Capri axles
I was actually gonna use the kia 1 piece axles.Originally posted by Damkid View PostWhy swap bell housings? It's the same tranny internally as the Capri XR2
So considering the ZX2 already uses a 26 spline diff, the axle diameter should match up to the Capri axlesSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Why !?!? The half shaft will minimize torque steer. And the BP with stock tranny and axles had wicked torque steer hard to keep it straight.Originally posted by nitrofarm View PostI was actually gonna use the kia 1 piece axles.:cry_smile: RIP. 91 Ford festiva BP swap
1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
In my world, capris are obsolete. I'm looking for alternatives to using anything capri or escort GT. Stuff that when it breaks, I won't be months trying to find a replacement :p
If the housing is the same, and the zx2 bell housing bolts to a B series motor, then I wouldn't have to swap them, but I'm wondering what I might need... it's all just hearsay tho, I will figure it out when I get that far I suppose, it just helps if you have a clue what your doing before hand lol... escort zx2's are a dime a dozen tho..
on car-part.com, the closest merc capri transmission to me is 147 miles away, the next closest being over 200 miles... and good luck finding one in a junk yard around here, they won't even let you in the gates at most places.Last edited by zoom zoom; 02-25-2012, 09:48 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Originally posted by zoom zoom View PostIn my world, capris are obsolete. I'm looking for alternatives to using anything capri or escort GT. Stuff that when it breaks, I won't be months trying to find a replacement :p
1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
What's this bellhousing swap stuff you keep talking about? The bellhousing is integrated as one whole half of the trans, you can't just remove it & replace it with a different model, you achieve the same thing as just using a different trans. There's nothing to be gained by this. Just use the whole transmission?Originally posted by zoom zoom View PostIf the housing is the same, and the zx2 bell housing bolts to a B series motor, then I wouldn't have to swap them, but I'm wondering what I might need... it's all just hearsay tho, I will figure it out when I get that far I suppose, it just helps if you have a clue what your doing before hand lol... escort zx2's are a dime a dozen tho..
You are making this way more complicated than it is1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
I'd go with just stupid if I were you.. why you so mad bro?
I understand the bell housing is integrated, and what I mean by that is to split the case open and swap the front half.. but I do make things more complicated than they are, so I'll quit asking about it until I need to know..next week.Last edited by zoom zoom; 02-25-2012, 10:14 PM.2008 Kia Rio- new beater
I'm curious as to why you would want to swap one half to the other.Originally posted by zoom zoom View PostI understand the bell housing is integrated, and what I mean by that is to split the case open and swap the front half.. but I do make things more complicated than they are, so I'll quit asking about it until I need to know..next week.
The 5th gear sides are almost all the same between the gtypes. So what are you trying to gain by swapping the front half?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
^^ditto, you really would not gain anything by doing all that work lol
I see what you guys are talking about now, I didn't realize the gearsets are mounted to the front half of the transmission like that.
So the "bell housing" bolt pattern on the zx2 transmissions won't bolt up to my BP motor?
Am I really forced to find a capri g series? What other options are there??!!?!?!?
I looked at car-part.com again and I can get one 60 miles away from a 1991 capri b6t...is that what I need?Last edited by zoom zoom; 02-26-2012, 09:45 PM.2008 Kia Rio- new beater
The ZX2 trans will NOT bold up, 100% truth!
you can use either a capri XR2 or an 80's 323GT (turbo) 5 speed, or you can use an Escort GT or Protege LX or Tracer LX-E 5 speed trans but you will have to go hydro clutch.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Yea I'm really not looking foward to a hydro setup, I'll be lucky if I ever get a cable transmission in place with this car and that just seems like more of a headache lol.. I need to get something figured out tho, I should have the block back from the machine shop by the end of the week and I really want to get this car put back together as soon as I can.2008 Kia Rio- new beater
Post a [WTB] ad on here. I know a few members have g series sitting around.-Greg
Redneck Engineer
FOTY - '09
