im new to the aspire world of modifications. i have a 96 with the b3 motor and a manual transmition. my motor is getting up there in mileage and im looking to do a rebuild with a couple unique motor mods.
1. while i plan on doing my rebuild to its fullest (valve job, head planeing, new bearing and gaskets, inspecting my injectors) i want to modify my internals without spending too much money. im looking to build a high compression na motor. idk if anyone makes a high compression piston for these cars, if someone does! thatd be great and answer the whole rest of the number 1 idea. some company (cant think of the name right now) makes an aluminum epoxy. its supposed to be machinable and acts just like alu when its dried/hardened. the product is alumaputty. i think itd be great to add this to my combustion chamber be it on my pistons or up on the head. i could build a nice quench head to help with the fuel swirl or just build the pistons up a little to take up more space. anyone with inputs on the product, the placement, or a replacement(high comp pistons).
2. my second biggest part of the build would be on the intake side. i will design a water/meth steam injection system. now everyone knows (or should know by now) of the benefits of water injections. knock resistance, steam cleaned internals just to name a couple. performance guys use ambient water temp sprays into their intakes to help cool a turbo charge, and to keep the egts down under load- deseil guys. with the steam injection i want to have it warm up my intake charge and the steam will take up more space of were the air should be. this should require my throttle body to open up more under cruise which would in turn raise my intake side efficiency. i know you might shake your head and say that the warmer air may cause knock. but you have to realize that i plan on heater water/meth into the steam which methanol is a fuel known for its knock resistance. at if worse comes to worse, the steam still have plenty of ability to absorb unwanted heat outta the combustion chamber. share inputs on steam injection setups please
3. i am in the process of building a new header for the car. ive seen a couple after market jobbers that people have slopped onto their 1.3ls. but i think these look way too flowy with their big primaries. you may ask "whats wrong with flowing". well....not really anything....but ive read multiple times that ever 1/8 inch the primaries are sized bigger, your torque peak raises by 700rpm. so if your pipes get too big, our baby motors may never be able to take advantage of the size. thats why im planning my header build around a 1" primary and 1" secondary header. and i plan on making the rest of the exhause 1 and 1/8 inch pipe. all these measurements are internal diameter fyi. i want the primary lengths to be around 1 ft. and the secondaries of this 4-2-1 header to be longer than 2 foot. ive researched and longer lengths seem to be the best the tune my motor for max tq at my cruise rpm....which im guessing is around 3.3k at 65mph. the biggest problem im having is sourcing a flang to attach all my pipes to. does anyone have any flanges already made up...or are there any alternatives. ive built one header already (urine poor design) but it did achieve me a constant 39 mpg bump from 36. i used the stock exhaust manifold which was just chop sawd from the rest of the pipes. i believe the stock manifold to be crappy design and i would like to get one that is port matched for my motor. any ideas here? is the 1.6 ports the same as the 1.3l?
thanks guys. if you made it to here! im proud of you for reading past my gramar errors. but just lemme know what you think. hp doesnt matter. im not building a race car. i just want max mpg. id love to say i get better than a prius!
