Originally posted by FestYboy
engine rebuild and fuel economy mods
No. I am too impulsive/impetuous at times. Fuel economy largely seems to be taken entirely for granted on this forum and every manner available to take away from that seem to be much more the norm here. How many versions of "I really would like to get 50 mpg and/but it's more important to have 200 hp on tap" have we seen over the years.Originally posted by Pu241 View PostBert, I guess the title didn't provide a clue?
So: My sincere apologies.
However a 'massaged' 5 speed 3 banger Suzuki transplant driven with a soft foot ought to provide all the fuel economy and aggravation anybody could wish for, along with taller thinner tires, and removing the roof and all of the upper glass.
I suspect that the easiest way to learn or get one of these (if what you're talking about is OEM) is to find a dead Aspire that still has an engine with cam and head. Guaranteed they will be scarce as hen's teeth in another 10 years.Originally posted by bhearts View Postcould you show me a link for an aspire roller follower cam and adjustable cam gear. ive been looking all day for both.
remember it is thrown away two dollars per tank full to run high octane verses 87 octane. take my word for it you will be running premium fuel if you're going for high mileage with advance timing high mileage with increase compression hugh mileage with air intake modification or a combination of all of those. I did lots of modifications to my aspire to increase mileage but it only affected the highway. driving in the city I could not tell because of the variation of every single trip I take. if you plan your routes to never use reverse and hardly use the brakes, run stop signs and check the engine off at signals and trains you can see huge gains but your data still willo be tank to tank or week to weekLast edited by getnpsi; 10-17-2012, 05:04 PM.1993 GL 5 speed
How about 200hp and 50mpg? HP doesn't have to come at the expense of low mileage. In fact, my B6t car gets 4 mpg better mileage than my bone stock 93 auto Festiva and my bone stock 89 auto Festiva. With a properly tuned turbo engine, 50mpg and 200hp is possible. I have tuned a mk5 vw gti 2.0fsi to over 200hp and slightly over 50mpg. This should be possible with a Festiva.Originally posted by Bert View PostNo. I am too impulsive/impetuous at times. Fuel economy largely seems to be taken entirely for granted on this forum and every manner available to take away from that seem to be much more the norm here. How many versions of "I really would like to get 50 mpg and/but it's more important to have 200 hp on tap" have we seen over the years.
However a 'massaged' 5 speed 3 banger Suzuki transplant driven with a soft foot ought to provide all the fuel economy and aggravation anybody could wish for, along with taller thinner tires, and removing the roof and all of the upper glass.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Use a hydrogen injection system, with hydrogen made from water. Turn up the power
a little and you will get steam with it. Truck air brake antifreeze mixed in is the
cheapest alky I find out here..
Hydrogen is worse than alcohol for corroding metals, I use poly carbonate and dairy
rated hose to deliver the goods to the throttle body. All inexpensive and easy to
make parts. Don't believe all the hype if you google this.
The benefit comes by adding
some hydrogen that burns extremely fast compared to diesel or gasoline. Flame fronts
will streak through out the combustion chamber and burn from many points, not just
the spark plug , and promotes burning the fuel molecules that the catalyst normally
burns. The exhaust runs cooler, the cat does not work anymore and the engine sounds
different.
So far I have not heard any engines ping while the system is working, this would be because the flame front progressing across the chamber and compressing
the end gasses has been eliminated. Quench and the fuel trapped there must be burning too, or the catalyst would still be working.
I love projects like yours and will be following!Reflex paint by Langeman...Lifted...Tow Rig
I tried this on my old neon. Didn't make any difference at all that I could tell MPG wise. It seemed to help the bottom end a bit, though. Mine was putting out steam too.Originally posted by Movin View PostUse a hydrogen injection system, with hydrogen made from water. Turn up the power
different.
I love projects like yours and will be following!Any difference that makes no difference is no difference.
Some have to have the o2 sensor black boxed to add about .2 volts to the signal
going to the computer. The hydrogen is mixed with 2/3 oxygen and this causes
additional fuel to be added on some vehicles.
Another way around that is to put the oxygen in the passenger area and inject only
Hydrogen. Easy to do.Reflex paint by Langeman...Lifted...Tow Rig
im still at a loss for what motor to choose. i have the aspire 1.3 now. but that 1.6 sohc everyone talks about really has my ponies rumblin in my mind. while it still have the gas saving abilities, the extra umph up the hills, cant say no to that. what year 1.6l swapps into the aspire the easiest.
88-89Trees aren't kind to me...
since you have an aspire andt have to re harness a lot of the car you might as well get the dual overhead cam 1.5L protege. it is unclear how well you can make a 1.6 engine run with just 1.3 electronics. since most people have festivas on it festy messe board it is a no issue1993 GL 5 speed
Get an early b6 and put all your stuff on it. Megasquirt, and a wideband o2 would be great tuning tools for you. I just did a B6 SOHC, rear turbo for a member here(Kumalaba) and he's getting 38 mpg, while making well over 120hp, which is double stock, plus some.
TominMO's car was the same setup, and he recorded 50+ with his, @55mph. Still b6 turbo.
Both cars have an FMU, so when not in boost, they are the same as stock.-Greg
Redneck Engineer
FOTY - '09
I averaged 36 MPG when my festy was b6t, had a lot of 40 MPG fills and a best of 47 MPG. Not bad considering the liberal (safe) fuelling of stock electronics.91GL BP/F3A with boost
