I have Rio axles in my bpt/g series....no noticeable torque steer.
2001 kia rio manual transmission swap?
I didn't notice torque steer on my test runs, but I didn't do a whole lot of driving it yet. It also has a stock BP, so it doesn't have that much power. Torque steer is also affected by suspension geometry. If you have wider tires it will get worse since you'd have a larger scrub radius. I'm running stock miata 14" wheels.
Should also note that the right side mount had to be modified going from the E trans to the Rio trans. The whole drivetrain had to be moved to the right to fit in the longer gearbox.
