Rocketman Carb Adapter
    That is beautiful design work.......:thumbs_up:
    Qudos,
    Jack Byrd,
    1991 Capri
    1988 Festiva LX, 240K
    1970 Chev C10
    1977 Airstream Argosy MH
      Fits the manifold pretty well! I'm hoping to have this one finished sometime tomorrow
      1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
      Rocketchips!
      Bolt-on Weber Carb Adapters!
        i wonder what the swirl looks like and if those 2 steps help or hinder.... in either case it's a marked improovement over stock.
          I'm not sure, they seem like they'd be good if the carb was *right* on top of them ala stock, but then again there's that plastic preheater bit in there blocking things up too. At least on the manifold I got ahold of
          Rocketchips!
            Finished the DRO install on my mill, used it to measure the stock flange hole locations & used the measurements to drill out the manifold side:
            Weber side is next.
            Rocketchips!
              Nice work as always Rocketman!
                Subscribed! I have a friend I might buy one of these for
                  Looks good. Can't wait to get my garage finished so I can have cool tools like that.
                  "Its not fast, but its fast for a festiva."
                  • #24
                    First one's done!
                    -Rocket
                    Rocketchips!
                    • #25
                      Looks very nice rocketman only prob i see is with my weber carb im running the larger oval air filter and it barely clears the hood with the adapters i made which are not as tall but as long as people are using the flat air cleaner that comes on the weber should fit fine. Wish i had the tools to do my own machining... i have to pay my machinist to do it. But maybe here in the near future i will be having him make me a nitrous plate for the weber:evil2:
                      • #26
                        Hey rocketman, i just posted on my weber adapter plate thread that you also have an adapter going into production, hopefully that helps you. I started making mine as just a way to help people that didnt have any other way to fit a weber onto a festiva.
                        • #27
                          I want one, take my money now! Haha
                          Seriously though, I need a new carb anyway, and didn't want to stick another feedback on, I will contact you soonish?
                          Mike Holmgren
                          Thief Rvr Fls, MN
                          1989 Festiva L, carb. 4 spd.
                          "If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
                          • #28
                            How much?
                            • #29
                              Drumnerd33,
                              These sit a tad over 1.75" tall. It's taken me a while to get the tools together to make stuff like this. Thanks for the link from your thread, I've wanted to make these for a long time & finally confirmed my design at the last Ohiostiva. It's good to have options!
                              Price: Looking at $65 shipped right now. I need to make some jigs to speed up the process, and find some cheaper studs but that's about where I figure it'll be.
                              Rocketchips!
                              • #30
                                Nice 1.75" isnt too bad. Im impressed with your work.
