Nice work. That is a great price for a custom piece like that, too.
Rocketman Carb Adapter
Got word tonight that the prototype fits correctly & works as intended. I still need to source the carb studs in bulk but otherwise good to go on production.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Nice work as always Rocketman! +1Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Studs with an Allen head in them like the wheel studs we replace our lug bolts with would be pretty cool. Not totally necessary but would help.
I would imagine that 1.75" adds some torque too like a phenolic spacer.91GL BP/F3A with boost
Today's work. If anyone is interested there are some from this batch not yet spoken for. At the moment I cannot find a small enough quantity of the cheaper hardware, so. Price is $70 SHIPPED to the US. Canada, contact me for shipping info.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
So if you put all five of those together would it give some sort of ram-airflow effect?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
kool....:thumbs_up:Originally posted by Rocketman View Post
Today's work. If anyone is interested there are some from this batch not yet spoken for. At the moment I cannot find a small enough quantity of the cheaper hardware, so. Price is $70 SHIPPED to the US. Canada, contact me for shipping info.Jack Byrd,
1991 Capri
1988 Festiva LX, 240K
1970 Chev C10
1977 Airstream Argosy MH
Ordered a few days ago.
Can'twaitcan'twait
CAN'T WAIT.
-JoeWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
darkfact, I'll chime in because I just installed mine yesterday with Rocketman's adapter.
My friend and I removed all of the old carb and vaccum system insanity, installed the 32/36 DGEV (Suzuki Samurai Kit - $230 on Ebay)) and my '88 started up on the first try. We were blown away that we didn't even need to adjust the idle speed!
The throttle cable bracket was the only thing I needed to fabricate. Also, all the old vacuum ports on the intake manifold have to be plugged (I used 'loops' of hose, plus the caps that came with the Weber kit) and you have to reroute the valve cover vent to the new air cleaner (1/2" tubing).
There is no problem with hood clearance.
I drove the car today and it is wonderful, I was fuly expecting to have to tinker with the new Weber before getting it to work right, but I haven't had to at all.
^ +1. I'm curious, why did you go with the Sami kit specifically?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
