Rocketman Carb Adapter
  • #31
    Nice work. That is a great price for a custom piece like that, too.
    • #32
      Got word tonight that the prototype fits correctly & works as intended. I still need to source the carb studs in bulk but otherwise good to go on production.
      1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
      Rocketchips!
      Bolt-on Weber Carb Adapters!
      • #33
        Nice work as always Rocketman! +1
        • #34
          Studs with an Allen head in them like the wheel studs we replace our lug bolts with would be pretty cool. Not totally necessary but would help.
          I would imagine that 1.75" adds some torque too like a phenolic spacer.
          91GL BP/F3A with boost
          • #35
            Today's work. If anyone is interested there are some from this batch not yet spoken for. At the moment I cannot find a small enough quantity of the cheaper hardware, so. Price is $70 SHIPPED to the US. Canada, contact me for shipping info.
            Rocketchips!
            • #36
              Man those came out good!!
              +1 for an awesome mod and excellent craftsmanship :thumbup:
              WWZD
              Zulu Ministries
              • #37
                So if you put all five of those together would it give some sort of ram-airflow effect?
                • #38
                  kool....:thumbs_up:
                  Jack Byrd,
                  1991 Capri
                  1988 Festiva LX, 240K
                  1970 Chev C10
                  1977 Airstream Argosy MH
                  • #39
                    Ordered!
                    White '88, 280kmi, Weber 32/36 DGEV Carb with Rocketman Carb Adapter
                    • #40
                      Rocketman, are your weber Adapters for $70 a 100% bolt on solution with no additional fab work required? And also, is there any issue fitting it under a stock Festiva hood?
                      1989 Festiva L Carby
                      • #41
                        Ordered a few days ago.
                        Can'twaitcan'twait
                        CAN'T WAIT.
                        -Joe
                        1988 LX 5-speed
                        Gone:
                        • #42
                          darkfact, I'll chime in because I just installed mine yesterday with Rocketman's adapter.
                          My friend and I removed all of the old carb and vaccum system insanity, installed the 32/36 DGEV (Suzuki Samurai Kit - $230 on Ebay)) and my '88 started up on the first try. We were blown away that we didn't even need to adjust the idle speed!
                          The throttle cable bracket was the only thing I needed to fabricate. Also, all the old vacuum ports on the intake manifold have to be plugged (I used 'loops' of hose, plus the caps that came with the Weber kit) and you have to reroute the valve cover vent to the new air cleaner (1/2" tubing).
                          There is no problem with hood clearance.
                          I drove the car today and it is wonderful, I was fuly expecting to have to tinker with the new Weber before getting it to work right, but I haven't had to at all.
                          • #43
                            BTW, ignore the Fuelly MPG in my signature - that was the MPG I was getting before the new Weber carb!
                            • #44
                              You are gonna want to rejet the carb, it will run with the jets that are in it but you will be way rich and burn Alot more fuel then needed and you will notice the black crap that builds up on the back of your car.
                              Sent from my LG-LS970 using Tapatalk 4
                              • #45
                                ^ +1. I'm curious, why did you go with the Sami kit specifically?
