Our forged power piston kit utilizes technology used in our most high end engine programs. With features found in F1, MOTO GP & recently NASCAR, make these pistons worth 25-35 HP all by themselves. Machined from 2618 forged billet stock. Features include -1.9 cc flattop, 12-1 compression, side relief skirts ( slipper skirts ), internal pin & skirt milling for weight reduction, double forced pin oilers & banana grooves ( for pressurized pin oiling ), pin circlip pick reliefs, valve reliefs machined to accept our OS valves & our high duration high lift cams, H13 tool steel wrist pins with friction reduction surface treatment. As well as moly coated skirts. Our ring package includes a F1 spec 1.0-1.0-2.0 ultra low drag ring set with PVD ( physical vapor deposition ) surface treatment & is custom made for our pistons. Combine these features to reduce piston drag from stock 13.1 lbs of pull per piston to our 2.8 lbs of pull. Making this piston kit the 1st & most advanced kit available for the Festiva crowd.
