Originally posted by bhearts
Help with parts selection for small turbo on my 1.3L
If your carb is setup to blow through, and you're running water meth injection, you won't have to choose the biggest jet possible, which could make you run very rich while off boost. Someone correct me if I'm wrong.Originally posted by herk518 View PostYea they can run for around 450$ on eBay... And they make it so you can run stock carb settings??
What I did realize is the carb I'm going to be using is a progressive carb which will work nicely for a turbo setupOriginally posted by bhearts View PostIf your carb is setup to blow through, and you're running water meth injection, you won't have to choose the biggest jet possible, which could make you run very rich while off boost. Someone correct me if I'm wrong.
