DIY ECU. beta testers? Anyone? :)
  • #16
    I have a odb1 I'm using for a hydraulic power plant. Easy to wrench/wire on.
    Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
    • #17
      I want to do this so bad. So say I don't care about the IAC stuff. What's the bare minimum I need to get started?
      And what's your "logic theory"(not sure if that makes sense) like? Is it along the same lines as MS or more like a perfectly programmable carb?
      • #18
        So I could use this to make better fuel maps in my Stroker? when to change loop modes? etc...
        1991 Smoketiva - 306k
        1997 Jeep Cherokee - 4.6L Stroker
        2004 Sebring
        • #19
          Never mind. Looked at your site. Sweet.
          • #20
            Originally posted by russian View Post
            As a redneck you should be capable of building a dyno like http://jalopnik.com/5807502/how-to-b...for-just-2000/
            Nah, rednecks can only make moonshine. And build rear-turbo cars.
            • #21
              I'm building my own ecu.
              I'm working with freeems.org
              We have a forum with a small yet very active community on diyefi.org
              Sent from my Agora Quad Core using Tapatalk
              1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
              • #22
                I know this site and this project, great stuff tthere!
                It's just that i do not agree with all the concepts and thats why i have my own project. But right now you guys are totally in front and i am jealous.
                Still, i believe things could be done in a simpler and more modular way.
                rusEfi - DIY ECU
                93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
                • #23
                  Hahaha.... They have the same views about megasquirt. That's the reason they started free ems.
                  The good thing is that ultimately, the system lends itself to run in almost any configuration you choose (provided you know how to make the changes and build the hardware to suit)
                  The ultimate thing is that we are all working with open source software that allows us to do whatever we want with it.
                  This is my first build so I've ordered a board and components from one of the guys. But after I'm settled with the entire system, I'll be looking at building one from scratch in a configuration that is optimum.
                  • #24
                    I have created a page which should hopefully answer some questions - http://rusefi.com/forum/viewtopic.php?f=2&t=239
                    rusEfi - DIY ECU
                    • #25
                      is there opportunity to have like a "preset option" setup for different conditions? so say you're on the track, you can setup track settings, ETC?
                      That in my opinion would be very handy.
                      Ford Festiva 1991 WA Model (5 Door)
                      Nicknamed the car 'The Chiva' (Chilli Festiva)
                      Avg Economy:
                      Highway - 7.32L/100km
                      City - yet to be determined.
                      • #26
                        Eventually there will be. Right now we are not there exactly - we are definitely in a more earlier phase with a lot of legwork in front of us.
                        rusEfi - DIY ECU
                        • #27
                          Im so glad someone is doing this. Megasquirt used to be cheap.
                          -Greg
                          Redneck Engineer
                          FOTY - '09
                          • #28
                            Do you think you would be able to make a small harness extension?
                            I think so. I can solder, I can twist wires. I hope to have a car coming online in the next couple months to play with. Maybe sooner.
                            • #29
                              It seems like there is enough interest to make a small batch of at least the analog input boards. Ideally I would need to find someone who can fix my slightly imperfect board design or maybe I will just do it over the weekend, and we will see how this would go
                              rusEfi - DIY ECU
                              • #30
                                Do you have a PCB schematic?
                                Im happy to build and test your system also.
                                What code are you using gnu c?
