Originally posted by TominMO
i took a hair dryer to each "primary" and got air flowing through it.
Then i covered the other 3 primary starting points with paper on top of them.
what i saw was that the air going into the manifold was coming back out the wrong direction pushing the paper off the openings.
But when i did the same test to matt dick meyers long tube design.
the negative pressure wave created through the other primaries created a vacuum sealing the paper onto each opening.
Which just goes to show you how effecting the scavenging effect was on the long tube header.
and the fact that the factory aspire manifold had no negative pressure scavenging rather it was forcing air back into the other chambers.
just thought id share.
