Originally posted by TWFodor
Engine reassembly questions
FYI, B6 and B6D both tighten to 60 ft-lbs. So there does not seem to be a difference between any B3 or B6 as far as cylinder head bolt torque. Go for it.Last edited by TominMO; 09-15-2015, 02:09 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I took the cylinder head off to take a peek yesterday and found out for sure its a B3 block. It has the S7 number on cylinder 3, but included with the car was a head gasket still in the mail package. I took it out and it turned out to be a gasket for a B6 which is a bit different and will not fit. Time to order a new B3 gasket. Here's a few pictures from last night.
The injector rack seems a bit flimsy. Even the rack on my 90' seems heftier. Anyone seen this rack before or know what its from? The PO said it came with the head, so I'm assuming 121 but it just seems...cheap?
Picture0915152258_1.jpgPicture0916150813_1.jpgPicture0916150816_1.jpg1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
The PO said he had the cylinder head acid-dipped.
This is the wrong gasket that came with the car:
However, now I'm confused again. The gasket for the B3 (Part number 9555 PT) doesn't look like it fits the block:
That being said, the gasket for the 1992 323 (the car the PO said the block was from) does (Part number 9696B:
I keep spinning in circles.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
DUDE!!! It's a 16v with mechanical lifters!!!
If you don't end up using it for whatever reason I want those!Last edited by sketchman; 09-16-2015, 09:58 AM.Any difference that makes no difference is no difference.
So it's a gen2 B6 block. The S7 casting confirms it as a gen2 B6. What does it say for motor ID, where the block serial # is?Originally posted by TWFodor View Post
Gen1 B6 (1986-89) used a different HG than the gen2's. That was probably your confusion about the B6 gasket you had not fitting, and thinking that the block must be a B3. The B3 will have a smaller bore tho; so the cylinder hole in the B3 gasket will be smaller than the B6 cylinder. The one that came with the car musta bin a gen1 B6 gasket.
I contacted the PO on Friday night, the day before you went out to buy that car. He told me he had someone coming out the next day to look at it. So close!Last edited by TominMO; 09-16-2015, 09:58 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
That's the thing, I wasn't able to locate the serial number. I'll take another good look after work later. but the S7 was on both the front and back of the block. On cylinder 3 in the front and on cylinder 2 in the rear.Originally posted by TominMO View PostSo it's a gen2 B6 block. Gen1 B6 (1986-89) used a different HG than the gen2's. That was probably your confusion about the gasket you had not fitting, and thinking that it must be a B3. The B3 will have a smaller bore tho; so the cylinder hole in the B3 gasket will be smaller than the B6 cylinder. The one that came with the car musta bin a gen1 B6 gasket. The S7 casting confirms it as a gen2 B6. What does it say for motor ID, where the block serial # is?1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
Sorry, I do plan on using it, but if anything changes, you'll be the first to know!Originally posted by sketchman View PostDUDE!!! It's a 16v with mechanical lifters!!!
If you don't end up using it for whatever reason I want those!1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
I'm so glad I was able to pick this one up! It will be a suitable replacement for my incredibly rusty 90 L Plus. I knew if I didn't get it last weekend it would be gone.Originally posted by TominMO View Post
I contacted the PO on Friday night, the day before you went out to buy that car. He told me he had someone coming out the next day to look at it. So close!1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
Cool.
So you're saying the 323 gasket fits the block but not the head? You might try a 92 MX3 gasket then. Since you have a B6 block but a 16v head. The 92 MX3 B6-ME is exactly that. The head you have probably has slightly smaller diameter CCs but you could blend the edges into the gasket size if it bothered you too much.Any difference that makes no difference is no difference.
No, I believe it should fit the cylinder head as well, but I haven't got my hands on it yet to check. I have to order it still. The gasket that is on the head now apparently was driven before from what the PO indicated. And that gasket looks just like the 323 gasket. I'll check out the MX-3 gasket if this doesn't work. Thanks for the input.Originally posted by sketchman View PostCool.
So you're saying the 323 gasket fits the block but not the head? You might try a 92 MX3 gasket then. Since you have a B6 block but a 16v head. The 92 MX3 B6-ME is exactly that. The head you have probably has slightly smaller diameter CCs but you could blend the edges into the gasket size if it bothered you too much.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
I have assembled the engine and torqued everything down, but I cannot get the car to start. I believe it could be the timing which is something I don't quite understand. I made sure the camshaft pulley lined up at 12 and 3, and I made sure piston #1 was at the top of the cylinder before I tried again. I did this quite a few times, but still could not get the car to start. I know I'm getting fuel because when I take the plugs out, they are wet with gasoline. My plugs are blackened, so I will be getting some on the way home from work today. Perhaps I'm not getting spark?
I just want to get this thing started. I even had a dream about timing last night and woke up with a headache, if that indicates how frustrated I am with this. I've looked on the forum for similar issues and it all seems very simple. Just make sure the pulleys are aligned properly and you should be good to go. Could I have another issue lurking elsewhere?
Heres the link to my video:
Also, I tried starting the car with the intake on and it produced the same result. Ignore the throttle cable, my wife moved it out of the way and forgot to unclip it.Last edited by TWFodor; 09-21-2015, 10:55 AM.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
I haven't done a compression check yet. I'll see about renting a tester while I'm getting the plugs later on.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
