Would be a Focus/Escape/etc 2.3 DOHC. I would personally never do one of those after replacing valves on one. The timing tensioner design is stupid, the timing setup (both cam and crank) is stupid, and they used torx head bolts which is, well, stupid.
NO2 stock b3?
Last edited by sketchman; 09-16-2015, 02:49 PM.Any difference that makes no difference is no difference.
Turbo b3 is the most fun set-up.-Greg
Redneck Engineer
FOTY - '09
Miatas are easy to come by here just the prices are too high I really sety sight s on a b6 dohc due to having toodify the firewall for a bp.Originally posted by bhearts View PostI think guys make miata bp engines work, so 1.8 from like 94 to 2000 or so. Or maybe that was only the head, Hell idk.
Sent from my SM-G900V using Tapatalk88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
99 Protégé 1.6 will bolt right to your stock trans, so yes it will work. It's a great engine too, but you will have clearance issues with the intake manifold.Originally posted by Meepersly View PostTrying to get fun and fast... Really fast! Would an engine out of a 99 protege work? I looked at a really good engine in one recentlyDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Is there a manifold I can bolt on off another car.Originally posted by Advancedynamix View Post99 Protégé 1.6 will bolt right to your stock trans, so yes it will work. It's a great engine too, but you will have clearance issues with the intake manifold.88 Ford Festiva LX "Miogi" B8-ME swapped.
Looks like there is a spot where a distributor can be installed if it had a different rocker cover. It looks like it would be possible to run this car using the festiva computer. Can someone confirm this? I know the cables and connections would be different but it wouldn't be too hard to change those. Probably wouldn't be too hard to pull the harness and computer either. Just it is an auto trans and working on such a setup seems possible as well but also a little difficult. Just newer engines get more complex and I want to make sure this is within my abilities. Probably possible since I did the efi swap.Last edited by Meepersly; 09-17-2015, 10:48 AM.88 Ford Festiva LX "Miogi" B8-ME swapped.
