Originally posted by bhearts
B6d exhaust manifolds
Thanks. I've never welded on stainless before, but the welds look similar to welds I've seen online. Maybe next time I'll try out my pulse setting and make the pretty welds.Originally posted by Meepersly View PostLooks awesome
Sent from my Z936L using Tapatalk
There is a ram horn on ebay for the b6d, but the flange doesn't fit without fudging the holes a bit.Originally posted by william View PostThose look cool I have a megan racing top mount converted to down mount and t3. I was gunna cut the head flange off and make a long tube for the b6d.
Are there any cheap headers out there with similar port spacig?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Would it be a bad idea to weld it with the flange bolted to the head? Would that warp the head?A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
That is a good way to limit the amount of warpage, but it can be difficult to weld around the exhaust studs.
It's best to make a weld fixture and have it cnc ground with a slight arc on the flange mounting surface, to preload the flange. The fixture should also be drilled with passages for purging the manifold while welding. If it uses fasteners with a low profile head, it'll be easer to weld around the mounting holes. Some of these fixtures are water cooled to control pre and post heat.Last edited by Advancedynamix; 01-18-2016, 09:49 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
still have to cut home for turbo flange before I weld it. First manifold almost fully done.
inside needs a little porting then ready to go.
