B6d exhaust manifolds
    Originally posted by bhearts View Post
    I suspect we could tee it with a restrictor, right?
    That's probably all the flowmeter is...adjustable orifice. We could put a needle valve on a tee'd line.
      Bingo
        still have to cut home for turbo flange before I weld it. First manifold almost fully done.
          Looks awesome
          Sent from my Z936L using Tapatalk
          88 Ford Festiva LX "Miogi" B8-ME swapped.
          93 Ford Festiva L "Haywire" Rat infested trashcan WIP
            Originally posted by Meepersly View Post
            Looks awesome
            Thanks. I've never welded on stainless before, but the welds look similar to welds I've seen online. Maybe next time I'll try out my pulse setting and make the pretty welds.
              Originally posted by william View Post
              Those look cool I have a megan racing top mount converted to down mount and t3. I was gunna cut the head flange off and make a long tube for the b6d.
              Are there any cheap headers out there with similar port spacig?
              There is a ram horn on ebay for the b6d, but the flange doesn't fit without fudging the holes a bit.
                inside needs a little porting then ready to go.
                  Ported. Turned out great.
                  • #24
                    Nice
                    • #25
                      How much did the head flange warp?
                      • #26
                        Would it be a bad idea to weld it with the flange bolted to the head? Would that warp the head?
                        A mechanic knows how; A technician knows why.
                        Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
                        Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
                        Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
                        FB Festiva page: Jared Bennett
                        Instagram: jaredbear82
                        • #27
                          The head regularly sees those kinds of temps, I think it would be fine
                          • #28
                            Well, the coolant keeps the head cool, but the exhaust ports are very toasty
                            • #29
                              That is a good way to limit the amount of warpage, but it can be difficult to weld around the exhaust studs.
                              It's best to make a weld fixture and have it cnc ground with a slight arc on the flange mounting surface, to preload the flange. The fixture should also be drilled with passages for purging the manifold while welding. If it uses fasteners with a low profile head, it'll be easer to weld around the mounting holes. Some of these fixtures are water cooled to control pre and post heat.
