Originally posted by azgtx
What to expect from t25/t28 hybrid?
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Originally posted by azgtx View PostGarret type will not work with an IHI. You will need to make something. I could be wrong but the B6t is mechanical and doesn't work with anything that I know of other than the OEM ecu.
The microtec people say the lt8s controls fuel and ignition. BP seems to think it will work as well.
My next big task is how to install the ecu. Im gonna have to get their diagram and check it vs a capri ecu. I would love to be able to plug the capri out plug in the microtec wire the power and other stuff up and let her rip. Im betting its gonna be all new everything.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
just ordered my injectors and my ecu adapter to laptop kit.
Still gotta get oil feed line, coolant feed line, oil return, coolant return, aem wideband, new/cheap laptop, and the tune.
any idea on good but not the most expensive places to get that stuff.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Mike, what a/r is your turbo? That makes a difference too.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Originally posted by azgtx View PostI think those are like .55 compressor and .80 turbine. They sell them for the sr20 crowd.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
it looks like .55 and .861990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
anyone know the fitting size on the oil feed and return?
I might be able to cut down the oil return and make it work. Im wondering about oil feed now tho. About to buy an ebay kit but dont know the size of the tap in the block for it.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Originally posted by azgtx View PostB6t distributor or vaf very well might not work with the microtech. Check on that.Originally posted by azgtx View PostGarret type will not work with an IHI. You will need to make something. I could be wrong but the B6t is mechanical and doesn't work with anything that I know of other than the OEM ecu.Originally posted by azgtx View PostI would be ready with a miata cas and coil pack just in case. Carlos was just working with a guy in Alaska getting an Evo ecu to run a BF GTX and B6t. Cas and cop's there.Last edited by Advancedynamix; 07-01-2016, 11:56 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostJust wanted to give Clay props for the helpful hints. You guys should listen to this guy, he doesn't chime in much, but when he does, he's probably trying to tell you something that will save you a little time and hassle.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
