Originally posted by william
b6t + G series
Looks like a good one William. I'd just put new seals and gaskets in it, check the bearings and leave the rest alone. Don't even pull the pistons if you don't have to. It doesn't look like it was blowing by much at all.
The small nosed crank will be fine with a nice new crankshaft bolt, a new keyway and some red loc-tite. Make sure to carefully TQ the bolt to factory specs. The reason that the crankshaft fail is usually because the bolt was not installed properly or it lost its TQ for whatever reason.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Few questions for you guys.
Where can I get the small nose crank bolt?
Also where can I find a flywheel for my g series? I heard the escort gt flywheel works but all I can find new is Aluminum And I would rather have a stock steal flywheel.
If I can't get new I'll be heading to the junk yard unless someone here has one that I can resurface.
I should have a small nose crank bolt sitting around. Are you interested in a used one?Originally posted by william View PostFew questions for you guys.
Mazda still sells the bolt and keyway. Go to a Mazda dealer and order a crank main pulley bolt and keyway for a 1989 miata.
Miata mecca is a good online source. Mike (the owner of miata mecca) always stocks those parts from the Mazda dealership. They are on eBay too, if that's easier for you.
Here is a remanufactured flywheelLast edited by Advancedynamix; 08-01-2016, 12:44 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Charlie, that links says not available or removed when I clicked it.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I fixed it. It's an eBay link, sometimes they are quirky.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Thanks I'll probably order on ebay there isn't a mazda dealer within 50 miles of Me.
As for flywheel I've got one from shadtree .
I'm still trying to get this crank bolt out without any way to hold the engine I'm gunna need to get a bigger impact.
William, I bought my SnapOn 14.4 impact wrenches from a Pawn shop. If you want to get a larger one you might want to try a pawn shop.Jerry
Team Lightning
93 L Lightning. BP
Will, I use a "Chain Lock" vise grip to hold the engine from turning. Its like a bicycle chain on vise grips. Wrap right on the pulley, lock the chain tight, then lock the handle against something on the engine. Then a trusty breaker bar and pipe, if need be.Originally posted by william View PostThanks I'll probably order on ebay there isn't a mazda dealer within 50 miles of Me.
I'm still trying to get this crank bolt out without any way to hold the engine I'm gunna need to get a bigger impact.Last edited by drddan; 08-01-2016, 05:01 PM.Dan
Tryed that and the pullie slipped inside it's self. The b6t and d have a built in dampener that is know to slip when it get some age oh it but I do have a b3 pullie that I could slap on there and break it loose. I'm gunna try that!
Sent from my SAMSUNG-SM-G900A using Tapatalk
