I am looking for a picture that shows what all i need to bash or cut to get my g series to fit. I need to know if i should pull motor and all or just pull trans. I have the mounts and all that i just need to know what to hit?
g series questions
g series questions
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLDTags: None
i have been looking for the thread but cant find a good one1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
But whereeeee haha I could put it in and check for myself but being as so many people have done it already being able to do the work before the trans even meets the car would be greatOriginally posted by bhearts View PostNotch the drivers side frame rail. Which may or may not need to be done depending on your motor mounts
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
See, this is the conundrum. Because it depends solely on whether or not you're moving the engine forward.Originally posted by Festiver View PostBut whereeeee haha I could put it in and check for myself but being as so many people have done it already being able to do the work before the trans even meets the car would be great
And personal alignment skills and the such.Originally posted by Festiver View PostBut whereeeee haha I could put it in and check for myself but being as so many people have done it already being able to do the work before the trans even meets the car would be great
If I could just see like stock placement then I could adjust but I'm forwarding 2.5"Originally posted by bhearts View PostSee, this is the conundrum. Because it depends solely on whether or not you're moving the engine forward.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I'm doing a bp g swapOriginally posted by bhearts View PostI don't think anyone has to cut frame rail with a b6d-g swap
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Idk honestly I know if you use the bp crank pulley vs. the b3 you have to notch the passenger sideOriginally posted by bhearts View PostIsn't it usually the passenger side that gets notched on that configuration?
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Right now it's bp E swapped and the alternator is super close but not touching do you think the trans location changes left to right? Thatd be a shame engine looks so good where it isOriginally posted by bhearts View PostI think is precisely why you'd want to test fit it first.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I see the issue. You can't test fit to mark for clearances if you can't get the engine to fitOriginally posted by Festiver View PostRight now it's bp E swapped and the alternator is super close but not touching do you think the trans location changes left to right? Thatd be a shame engine looks so good where it is
? The engine fits it's mounted I'm easily confused sorryOriginally posted by bhearts View PostI see the issue. You can't test fit to mark for clearances if you can't get the engine to fit
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
