Cant get my recently installed B6ME running
So you have verified fuel, spark and compression in the combustion chambers. Incorrect timing may be the missing link. Pull your timing belt covers. Rotate the engine until the crank gear is straight up at 12 o'clock and the marks aligned. Now look at the cam gear. The marks should be at 12 and 3 o'clock and aligned with the marks on the valve cover.
