Looking for a bit of help/guidance from anyone with megasquirt knowledge! Ive had my squirt (MS2 v3.0) assembled for about 4 years now, sitting idle. I have wired up a harness to adapt the MS to the factory wiring for my B3. The problem I am having is getting cam signal from the Festiva distributor. Following this guide it seems like I may need to add a mod to the board, but I am not 100% sure. When I initially built the MS, i just followed the standard online build guide with the addition of the mapdaddy 4 upgrade.
I currently have the BLU/ORG wire on the distributor (labeled PSOUT on the ECA diagram) wired to pin 36 on the MS.
I have the YEL/BLU "Crank Position Sensor" (CPS) signal wired to pin 24.
I do not see any RPM when cranking.
Running in 4g63 mode.
